Muncie vin #'s
Started by 68Zproject, March 24, 2007, 01:37:50 PM
68Zproject
Is there a "rule" to how the vin #'s were stamped on the 68 Muncie for the Z28?  JM's book shows one that has a 1 before the vin, I guess to denote Chevrolet?  Like 18nxxxxx and Pontiac 28nxxxxx.  I talked to a guy rebuilding my trans and he said he hardly ever sees the 1 before the vin #.  Is this 1 just on Norwood, Los, 68 Z's, certain production runs or what?  Or is it just supposed to be there and sometimes it doesn't get put on?
68Z28
Jerry@CHP
It's always 18N392050 on the vin stampings in '68.  I have rebuilt more than I care to talk about.
Jerry
Mark
It's stamped by the same machine that stamped your engine VIN.  Not only should the 1 be there, but the characters will always match the one on the engine pad.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
68Zproject
That's what I was hoping, thanks again Jerry.  It would be 18Lxxx for LOS cars though right?
68Z28
Quote from: 68Zproject on March 24, 2007, 03:22:44 PM
18Lxxxxxx for Los Angeles cars.  Also, the '68 Los Angeles built Camaros have the vin stamping on top of the transmission case.  This is where I found mine.
68Zproject
[/quote]  Also, the '68 Los Angeles built Camaros have the vin stamping on top of the transmission case.  This is where I found mine.
[/quote]
Is that fairly consistant?  I thought I had seen some on the side.
68Z28
Jerry@CHP
Yes, LA did that with any original 67-68 Muncie that I've seen.  Usually stamped at least three to four times.  On the very front part of the case, at the rear of the case, on the center bearing support, and the tailshaft lip.
Jerry
x77-69z28
67 doesnt have the 1 in front of it. 68 and 69 do.
Quote from: Jerry@CHP on March 24, 2007, 09:30:51 PM
Jerry
Now that's something I didn't know and will have to check!  Is it always at least three to four times?
Mark
Never seen a transmission stamped more than once (except for maybe an overstrike).
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Charley
I think I had a LA built 69 with it stamped probably four times on the top. Not overstrikes. Kurt probably has pics somewhere.
www.1970Z28Camaro.com
www.MCACN.com
red69
Were all Muncie's stamped with VIN's? Or just Z-28s
                     Pat
Steve68
Pat
Other cars received Muncie's, with the associated VIN stamped on them, other than just the Z-28.
Jonesy
Quote from: Mark on March 25, 2007, 08:03:12 AM
My 67 Muncie from LA Plant is stamped 3 times with the VIN
1969 Z28 Azure Turquoise
Jerry@CHP
I think the stamping on LA Muncies depended on the mood of the plant worker.  Many LA Muncies have come in here for rebuild and resto and there is no consistancy to them at all.
Jerry
