My Z arrived today!
Started by rspallina, May 08, 2015, 09:33:05 PM
It's fun speculating about all the 'unknowns', even if we never get factual answers to our questions~  :)
Bryon, you should retire.... then you could be as busy as you wanted to be...   :)
I'm meeting a car friend for a german lunch, chasing down some materials for the new det. garage I'm building, changing the oil in the Nomad for a trip to the mountains this weekend, and maybe a few other odds n ends ...
PS:  The Smokey Mountain Classic Chevy Roundup occurs in Pigeon Forge, TN this weekend (The Inn at Christmas Place).. :)    There's also the Good Guys meet at Titans stadium in Nashville, AND the ZR1 Gathering at the NCM in Bowling Green, KY... I haven't yet figured out how to be at all three!!
rspallina
Guys - has anyone ever noticed a D that is lower than the C??  I will take a pic and post it later today
Rob Spallina
2014 Camaro SS w/ 1LE Package - 376ci/426hp/6 Speed/3:91 (Summit White)
1969 Camaro Z-28 X33D80 - 302/290hp/4 speed/3:73 (Lemans Blue)
Daytona Yellow 69 Z/28
Quote from: 69Z28-RS on May 12, 2015, 06:54:17 AM
Rob's 'C' seems to have taken some 'licks', just as mine had.   It makes me wonder how those extraneous rocks that hit those 'C's .. always hit the C rather than the B, U, etc...?...      OR maybe the diff factory put those 'C's on the rears – of the late 69's, and then decided to 'remove' them, and banged them up at the factory intentionally?   (I think no one knows the real story or reasons for that – management made an unprecedented decision to continue production of '69 Camaros and Corvettes for an additional 5 months... so obviously things were in flux and decisions about '69 vs '70 issues made quickly ...)..
Rob's 'C' has the same relative spacing before the BU as mine does... almost all the 69 rears with the C.. the C is displayed a couple of character spaces to the left of the 'BUxxxxGy' code.. it's almost like they didn't want it to be considered part of the app code?   Is the 'C' used on 1970 3 letter diff codes displaced the same way?  Or are they closely spaced as if stamped at one time?
PS. Why don't we consider the 'E' as part of the app code as well? ...  :)
The "hits" are more than likely just coincidence, based on the location on the axle tube.  They are not an attempt to remove them, at least not by the axle plant or assembly plant.  And those are not the only ones I have seen banged up.
The 1970 codes are similar, with the C being spaced over.  There is at least one example of that in the axle thread, and I have others.
E is part of the code, but is only there to designate which limited slip carrier is installed inside, E being for Eaton.
I will see what I can find in the Chevrolet Service News documents I have, but the three letter axle codes were planned, not just done on a whim.
Added - I will look again tomorrow for the September/October 1969 CSN that may have notes on the 3 letter axle codes.
rspallina
#49
Thanks Daytona!  Gentlemen - i present you with a D.  Anyone know what that is all about?  Anyone else have the same.  Is it possible that the C was set as D and had to be changed?
Rob Spallina
That D is most likely an inspection mark.  I have seen that before and it is not near the application code, so not related.
69 Zee
Wow. .sure looks like a "D"  ???  Way to throw a monkey wrench into things Rob..   ;D
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
rspallina
I just came across it yesterday uncovering the C.  It seems a part of my thread went missing.  The pic that Gary reposted with the C circled in red after a member said they did not see it.  Do posts get taken down?
Rob Spallina
Yes the moderators see to it, sometimes they give an explanation sometimes they don't.
Hey Rob does it ever look like the motor was resprayed at one point? Looks pretty dazzling in that engine compartment... 8)
rspallina
It's been cleaned and detailed but does look good. Not sure if there is any new paint.
Rob Spallina
Quote from: rspallina on May 12, 2015, 03:52:50 PM
Edited by mistake.  My fault.  See above.  Gary can repost that pic if he wants.  I did not mean to remove it.  Sorry.
But if anyone can't see the C, they need to look closer or get glasses.  :D
And again, the D is most likely an inspection mark, it has nothing to do with the C BU application code.
69 Zee
Quote from: bcmiller on May 12, 2015, 10:27:19 PM
Funny Bryon, cause when I actually first saw the pic before Rob had posted and then again when he did post on #18,  I saw what looked like to me another character.  But I honestly didn't think anymore of it.   As I was also unaware of the "C" punched on the later rears until I read your axle thread.
Learning something new everyday on these 1st gens,  Smiley
Darrell
Darrell, I definitely had to have my glasses on to see it.  :)
rspallina
Guys - i just went to put gas in the Z and was curious to know what you guys are using.  The prior owner was putting 93 in it and putting in a lead additive.  Another buddy told me to put Rec fuel (90 octane) without ethanol as the ethanol is bad for the carb.  Any thoughts?
Rob Spallina
Quote from: rspallina on May 13, 2015, 04:53:19 PM
Go with the one on the left...
