1969 Muncie Transmission
Started by wisemanz28, March 03, 2015, 05:06:38 PM
wisemanz28
When did they start using bolts ( instead of using nuts ) to attach shifter rod levers on a 1969 Muncie transmission ? The transmission is a 660 main case and has a 306 side cover.
rszmjt
All 1969 Muncie trans used bolts, the flattened 3/8 type stud was 1968 and earlier
HOGDADDY
I have a 69 trans with earlier shifter rod mounting studs installed.
Quote from: HOGDADDY on March 27, 2015, 04:58:22 PM
Might have been modified over the years.  What is the casting number on the side cover?
VINCE Z28
Early 69 Muncie, Aug.19th 1968.
VINCE Z28
HOGDADDY
Quote from: bcmiller on March 27, 2015, 05:15:46 PM
3950306 is the number. I think it was modified to fit earlier Camaro.
