Final adjustment on RS Headlight doors
Started by sixt9x33rs, July 28, 2014, 07:27:31 AM
sixt9x33rs
I am doing some fine tune adjustments to my Gold car and would like to get the driver headlight door to close a little tighter. Before I took the car apart and painted it the doors were perfect. I have the passenger door adjusted great but the drivers doors needs just about a 1/4" more adjustment to close properly. I have adjusted the plate on the cross member all the way rearward and that is not getting me the last little bit of adjustment. The vacuum canisters are OER repops that work great but was wandering if I have one that has a shaft that is a little too long. Anyone had that problem, or is there another place where I should be looking to adjust to get this last little bit of adjustment?
Lawrence
'69 RS Z/28 65B, 711 Flat hood no spoiler, endura, 4:10 44K miles (Sold)
Charley
I have found that when you run out of adjustment you can solve it with a pry bar, no really, not kidding. Take a look at it and see which way you need to tweak the bracket holding the canister.
www.1970Z28Camaro.com
www.MCACN.com
rszmjt
The painted headlight door actually has movement on the inner aluminum door/hinge assembly. There are some captive cage nuts on the inner. If you loosen the screws slightly and the small body nuts toward the fender end, you would be surprised how much you can move them, including up and down.
sixt9x33rs
Quote from: rszmjt on July 28, 2014, 07:55:01 PM
Thanks I will look into that
jacmac
If you have a Chassis Service Manual, look at 12-3 ,-12-4.This is in the electrical-body & chassis section.Has rszmjt said you would be amazed at how much movement there is for adjustment!
69 Z10,69 ss396Chevelle, 71 Corvette
sixt9x33rs
Quote from: jacmac on July 30, 2014, 06:38:55 PM
jacmac, I went to that section and don't see where I can adjust headlight doors for RS
jacmac
sixt9x33rs
jacmac
12-4  Fig. 3 "Headlamp Panel Adjustment"
rich69rs
Richard Thomas
1969 RS
sixt9x33rs
Quote from: jacmac on August 05, 2014, 07:19:01 PM
Apparently we are looking at different reference materials. My AIM is setup UPC 12 with subsections A,B,C,D and then several sheets per section. I.e. sheet 12 B4. I can't find anything 12-4 figure 3. Thanks for the effort
jacmac referred you to the  "Chassis Service Manual, look at 12-3 ,-12-4."..  not the AIM...
sixt9x33rs
Quote from: 69Z28-RS on August 07, 2014, 08:12:08 AM
Thank you!!! Would be helpful if I paid attention to the help.
Thanks Jacmac
jacmac
sixt9x33rs
I have adjusted every possible adjustment on the driver's side headlight door and the door still does not close up snug like the passenger side. I have to assume the shaft in the accuator too long. I am going to get another and put it in to see if this is better.
