Radiator Tank Codes 1969
Started by Pacecar, June 23, 2014, 05:27:46 PM
Pacecar
Restoring a 1969 big block automatic with Turbo 400. I looked at the tank codes listed and did not see my code. The passenger side tank is stamped SB with a date code C. No codes on the driver side tank that I could see. It is a Harrison radiator. Any ideas what the SB code is ? has the correct brackets.  Thanks
VINCE Z28
Pacecar,click on the red CRG in upper right hand conner, click on UNDERHOOD you'll see 1976-69 camaro cooling systems,that should tell you what you have or need.
