Length of J-bolt for spare in trunk
Started by ZLP955, June 13, 2014, 09:23:23 PM
ZLP955
Could someone with a 69 Z please confirm the finish, correct overall length, and thread length, of the original factory J-bolt hook that is used to hold down the 15" spare in the trunk?
Thanks in advance for any help.
Tim in Australia.
cam69aro
i will try to get a pic of it tonight, i don`t have a spare bolted down and it is still original finish. will post info as soon as i can for you.
Eldon W 1969 z28 Black with born with driveline X77 38,000 miles-sold
2016 z06/z07 Corvette Black
cam69aro
ok, i resized a few pics Tim, also send you a pm. im not sure if the J hook was ever plated or had a finish. the bolt was for sure, shiny om back side but worn and rusted off the front side
69Z28
Hmmmm...6 inches long. I'll have to look at mine tomorrow but mine may be a little longer...I think....but who knows after 40 years and not being original owner.
GaryC
cam69aro
check your hold down nut too Gary, see if it was plated like mine. the more i look at the pic of my J hook it looks like maybe it was phosphate plated maybe ?
69Z28
Eldon. I think mine may be zinc plated but will have to look to make sure. I can check my survivor 69 Impala too, probably no difference with them, but who knows. Maybe Bentley or GaryW still have originals. Lloyd should have his original too.
GaryC
ZLP955
Great, thanks for the pictures. Much appreciated.
Tim in Australia.
rszmjt
hhmmm.
My 06A Z28 J bolt is 9&3/4" long dark coloured grey or Black/ phosphate and the wingnut is silver cad. Non space saver. Owned the car since 74.
cam69aro
well i bought my car from the 2nd owner in `96 (he got it in `70 for a grad present) and i never had a spare mounted in the car yet but will asap. i have a full spare set of YH wheels and will make sure the hook is long enough. i hope it is right or i will be scrounging the junkyards for one. what year Z ?
cam69aro
rs, how much of the hook threads stick out when the nut is down tight ? now im wondering if mine is right or not. oh well, i will find out when i bolt a spare down.
ZLP955
Interesting, the one pictured did look quite short. Assuming you use the jack base, and then the special curved wingnut, to secure the spare, wonder if that'd run out of length? I didn't mention bolt length for space saver spare because I thought that was only an option with 14" wheels, is that correct? I know the coupes and convertibles used different bolts due to the position of the spare in the trunk, maybe the 'vert has the shorter one?
Tim in Australia.
rszmjt
Quote from: cam69aro on June 14, 2014, 02:18:45 AM
Don't know how much thread sticks up when the spare is installed, but just the threaded section is 5&1/4".
Wing nuts are not all the same BTW.  Correct wing nut is 4&1/2" wide total and there is a small protruding section/collar where it goes through the jack base.
I will post a picture later, as well as wing nut differences.
I have owned this 69 RSZ28 since 1974, 42,000 mile survivor , Canadian Docs.
ZLP955
Mike, pics would be much appreciated when you have an opportunity.
Thanks, Tim
Tim in Australia.
rszmjt
Sorry, It was in the trunk of my car which was up on a drive on hoist in storage.
