June 69 Z28 Tachs
Started by Mark, May 27, 2014, 11:42:16 AM
Mark
Anyone have a Z28 with a 6K redline/7K top of scale tach in an 06a built norwood Z?  I know they should have been 6K/8K by then, trying to see if there was a shortage of the 8K versions in mid to late June, or if a tach was just swapped with an incorrect one.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
69Z28
My 06A 653104 has a 6x8 tach.
GaryC
Larry Gibson
I don't have any way of determining if my 06A came from the factory this way but it had a 5500 redline with 7000 rpm limit tach when I bought the car over 30 years ago. Last year I changed it out for a 6x8 reproduction. Also last year I pulled the engine & trans to fix a rear main seal leak and to do some cleanup under the hood and documented every part & part number and found most everything to be the correct  part number and date code. So my car could very well have left the factory with an incorrect tach. No way of knowing for sure.
Larry
427-KING
My 09D [Sept 1969 late] survivor Z28  has a 6000/7000 and I have also verfied from the original owner that it was never changed. It also has a Jan 20 69 dated  1111480.
Quote from: 427-KING on May 28, 2014, 08:15:10 AM
Doesn't your tach have a date stamped on the back??   What is that date?
(My 09C Z28 has a 6000/8000 tach and has the date on the back of it...)
ban617
my 03 D has a 6 X 8 tach. My buddies 01 C has a 6 X 7 tach
rszmjt
My Norwood 06A ( June 18) has a 6000/8000. owned the car since 74.
Just recently restored a  02B LA Z28, and it had the same 6000/8000.
Pics of the 6-8K I sold (stupidly) some time back. January '69 dated, it would have been perfect for my (non-gauge) X77, but monetary needs took precedence -
Regards
Steve Shauger
Steve Shauger
ZLP955
Quote from: z28z11 on May 30, 2014, 10:26:16 AM
Curious how you decode that date? Looks like '189', or is that ink stamp not the date code?
Tim in Australia.
69pace
The Julian date and the last digit of the year I think if I remember right. so the 18th day of 1969 Jan 18.
TeamCamaro - Moderator
ZLP955
Quote from: 69pace on May 30, 2014, 07:44:18 PM
Thanks Brian, makes sense. So tach date codes would be either 3-digits (up to 2nd week in April or so), then 4-digits.
Tim in Australia.
rszmjt
Steve Shauger
Steve Shauger
Quote from: paceme on June 01, 2014, 04:21:01 AM
Quote from: rszmjt on May 31, 2014, 08:21:38 PM
Quote from: paceme on May 30, 2014, 10:30:47 AM
My 9A has a 6000/7000 .
9A of 68 or 69?
1969
Steve,
Do you know the date on the back of it?  I thought they had switched to the 6000/8000 well before Sept??
My 09C car has an 8K tach; date on the back of it is '197 69'   which corresponds to July 16, 1969.  This is consistent with most other parts on my car, except for a few dated almost immediately in front of the engine assembly...  see photos.
ps.  I also noticed there's a label on the instrument cluster itself with large NN code (any idea what this is for?).. along with a speedo pn, and tach (with hand note - illegible unless it might be '8')??
Gary
