Camaro Research Group Discussion => Originality => Topic started by: cadmanof50s on December 29, 2010, 12:04:02 PM
Title: Heater box seal
Post by: cadmanof50s on December 29, 2010, 12:04:02 PM
Just preparing everything I need to put my '68 back together again.
According to the AIM, the inside heater box used the dash mat as the seal to the inside of the firewall. Also according to the AIM, the outside heater box cover used a sealing compound to the engine-side firewall.
I have seen gasket sets (available through the normal vendors) that  provide gasket seals for both these applications. Are these gasket sets correct? (Should I be using them?)
If sealer/caulking  is correct, what would be an appropriate sealer to use?  Black silicon...??? Body caulking? Could someone recommend a product please.
Thanks!!
VIc
Title: Re: Heater box seal
Post by: JohnZ on December 29, 2010, 01:02:02 PM
No separate gaskets were used originally. Black RTV is a good substitute for the bead of sealer used on the heater blower case groove.
Post by: KevinW on December 30, 2010, 08:06:06 AM
I used electrical putty (Dum-Dum) rolled out in a bead to seal the outer cover.  I used the putty (used for sealing wires piercing house walls and sold in lowes, Home depot) in a LOT of places, kick panels, rear bumper mounts, tinnerman nuts, cowl squirter seal, etc.
Post by: cadmanof50s on December 30, 2010, 08:13:39 AM
Thanks John and Kevin.
I like the idea of using the Dum-Dum as it stays pliable. That's very handy if (for whatever reason) you needed to remove the cover.
Post by: 68rs327conv on December 30, 2010, 10:07:40 PM
You can still buy the 3M 8578 Strip Caulk
Post by: BlackoutSteve on December 31, 2010, 12:56:32 AM
..or body sealer listed on page 167 (B-11608) It's what I used to seal my heater box cover and a bunch of other things.
http://www.amkproducts.com/Catalog_PDF/165-176.pdf
Post by: KevinW on December 31, 2010, 08:40:23 AM
I like the Electrical putty because its a dark charcoal, the strip caulk you can get in stores is a beige.  AMK wants a $30 min order last I looked + ship.  HD or Lowes is a lot cheaper (under $10 I think) and I am there a lot anyway :)
Post by: BlackoutSteve on January 01, 2011, 09:28:53 AM
Quote from: KevinW on December 31, 2010, 08:40:23 AM
They do, but are you saying you can't find other stuff to order?
Everytime I flick through their catalog, I have a another list as long as my arm! :P
Post by: KevinW on January 01, 2011, 12:21:15 PM
Quote from: BlackoutSteve on January 01, 2011, 09:28:53 AM
I do have a wish list fo AMK, but then I mostly find what I need in my misc bolt boxes. :)  When I get stuck, i will put in an order :D
