Camaro Research Group Discussion => Decoding/Numbers => Topic started by: Chuck-68-Cam on July 22, 2022, 10:33:53 AM
Title: Help with numbers.
Post by: Chuck-68-Cam on July 22, 2022, 10:33:53 AM
My car is a 68 350 TH400.
Waiting on more parts so I thought I would hunt down some numbers to see what I have. For the engine, I found a few numbers on the block but I could not find the typical double code. I did find the one number listed in block casting numbers chart. They appear to be used for 327 and 350 in 1967 models.
Question: Does that mean this motor is out of a 67, or are the blocks widely used across other models and years and 67 just happened to use these particular blocks?
Is there a way to tell if it's a 327 0r 350?
Found a tag on the transmission left side up on the bell. I could find nothing that looked like the numbers I found on tranny tag. Any info would be appreciated.
Found numbers for exhaust manifolds. Is there a way to identify numbers on exhaust manifold?
Any info appreciated. Thanks
Title: Re: Help with numbers.
Post by: Chuck-68-Cam on July 22, 2022, 10:42:08 AM
I am trying to post more pictures but having issues with size requirement.
Post by: Chuck-68-Cam on July 22, 2022, 10:42:42 AM
More pics
Post by: Chuck-68-Cam on July 22, 2022, 10:43:10 AM
More pics
Post by: Chuck-68-Cam on July 22, 2022, 10:43:32 AM
More pics
Post by: Chuck-68-Cam on July 22, 2022, 10:44:09 AM
More pics
Post by: Chuck-68-Cam on July 22, 2022, 10:44:33 AM
More pics
Post by: Chuck-68-Cam on July 22, 2022, 10:45:27 AM
More pics
Post by: bertfam on July 22, 2022, 11:05:58 AM
Yes, the block is a 67 (cast on February 1st, 1967) but unfortunately, it's been decked so there's no way to know what it was originally. However, if the engine is out of the car you can check the crankshaft flange and that'll tell you what it currently is (see below).
Post by: Chuck-68-Cam on July 22, 2022, 12:52:35 PM
Excuse my ignorance, still learning here. What is decked? Also, so that means does that mean this came from a 67 Camaro, or that it is a possibility it came from a 67 Camaro?
Post by: bertfam on July 22, 2022, 12:57:47 PM
Decked means the engine block has been machined down as shown in THIS VIDEO (https://www.youtube.com/watch?v=UOYpbFiT8Rk). This is typically done when the engine is rebuilt.
Post by: Chuck-68-Cam on July 22, 2022, 01:04:26 PM
Cool video. So maybe my numbers were at front passenger but were filed off during the rebuild?
Post by: Chuck-68-Cam on July 22, 2022, 01:07:15 PM
Maybe someone out there knows about this car? Any history?
https://www.streetsideclassics.com/vehicles/3326-nsh/1968-chevrolet-camaro-ss-350-tribute
Post by: bcmiller on July 22, 2022, 01:09:36 PM
It is a 1967 small block engine but it could be a low horsepower 327 and those did not get VIN stamped on the front pad.
Clean off the pad with some lacquer thinner on a rag, take hi resolution pics and email them to me at bcm66@cox.net and we can determine for sure if it has been decked. I am not convinced but it may be the case.
Corrected to add "VIN".
Post by: bcmiller on July 22, 2022, 01:10:34 PM
Well it says right in the ad that it is an SS 350 tribute, so it is probably not originally an SS 350 car.
Post by: bcmiller on July 22, 2022, 01:12:19 PM
And only big block equipped 1967 Camaros with the 396/325 hp engine got the TH400 transmission.  1453 produced.
Post by: bertfam on July 22, 2022, 01:16:50 PM
QuoteIt is a 1967 small block engine but it could be a low horsepower 327 and those did not get stamped on the front pad.
C'mon Bryon. It should at least have the suffix code! You know that!!
QuoteAnd only big block equipped 67 Camaros with the 296/325 hp engine got the TH400 transmission.  1453 produced.
His car is a 68, so 5,466 Turbo 400 transmissions.
And no, the car's not in the database.
Post by: Chuck-68-Cam on July 22, 2022, 01:17:23 PM
Thanks Bryon. Yea I know, I have a hodgepodge of different items on this car. That is why I am trying to get more info on where these items originated. I can't even be sure it's a 350 in there with out more info. I will clean and send picture.
Post by: bcmiller on July 22, 2022, 01:20:08 PM
Quote from: bertfam on July 22, 2022, 01:16:50 PM
QuoteIt is a 1967 small block engine but it could be a low horsepower 327 and those did not get VIN stamped on the front pad.
We will see with the new pics. Play along Ed.  :)
A 1967 CE engine would NOT have anything stamped on the pad in most cases.  :)  And those were not decked. I am not convinced this one was decked, yet.
Post by: bertfam on July 22, 2022, 01:24:46 PM
QuoteA 1967 CE engine would NOT have anything stamped on the pad in most cases.
I disagree with that statement, but I'll let you take the wheel.
Post by: bcmiller on July 22, 2022, 02:00:09 PM
Quote from: bertfam on July 22, 2022, 01:24:46 PM
CE stampings started in about late August of 1967 for the 68 model year. Many examples of blank pads.
Post by: bcmiller on July 22, 2022, 02:08:42 PM
Train wreck, I need to stop responding by tiny phone screen.😳🥲
I was going by the engine casting date!   B 1 7
If it was a CE engine from that time, it would NOT have gotten stamped. End of story on that.  If it was a warranty engine, there will be some information stamped on the underside of the starter mounting pad area with the assembly plant, month and year of assembly but that's it.
I can't tell from the pics if it was ever stamped or if it was decked and modified. Doesn't matter.
Bottom line. Engine is not original - it's a 1967 engine in a 1968 car, so no go.  TH is not original - those were only installed in big block Camaros from 1967 to 1969.
Post by: Chuck-68-Cam on July 22, 2022, 02:11:53 PM
Quote from: bcmiller on July 22, 2022, 01:09:36 PM
Pictures were sent. Putting one here also.
Post by: bcmiller on July 22, 2022, 02:20:47 PM
See above.
Bad day. I am taking the rest of the day and the weekend off.   :-[  :o   ::)   :-X
Post by: Chuck-68-Cam on July 22, 2022, 02:29:36 PM
All's good. I brain fart quite often...LOL Thanks for the info. Now hopefully I can get info on the maifolds and tranny. Thanks again guys.
Post by: bcmiller on July 22, 2022, 02:48:17 PM
WASN'T in the database, but it is NOW!
Post by: bcmiller on July 22, 2022, 02:56:50 PM
Quote from: Chuckman4112 on July 22, 2022, 02:29:36 PM
Engine not original. No big deal. My engine is not the original one to the car either.
Post by: Chuck-68-Cam on July 22, 2022, 07:12:32 PM
Yea, I knew when I bought it that there was not to much original on it. I am good with that. I am just having a good time making it better than when I got it.  :)
Post by: Chuck-68-Cam on August 08, 2022, 12:16:29 PM
Today I found this set of numbers by the filter. Do they tell us anything? I did not see these anywhere in the guides.
Post by: Chuck-68-Cam on August 08, 2022, 12:18:46 PM
Close up
