Author Topic: 1968 Camaro Window Crank Knob Color  (Read 18897 times)
rat pack
Re: 1968 Camaro Window Crank Knob Color
« Reply #15 on: July 27, 2012, 03:44:59 AM »
Shallow curve. The deep curve one didn't show up until 1969 on the rear panels only and it was the 9717838 cast handle. If I get time tomorrow I will dig some out for comparison, if not, then it will be Monday.......................RatPack................
Lane 68
« Reply #16 on: July 27, 2012, 03:59:10 AM »
Rat Pack....
Thank You again for your time and research on this!!
After I searched many threads, you were able to show us some great examples to our questions!!
I look forward to those other pics....When you have time !! ;D
Lane 68
« Reply #17 on: July 27, 2012, 11:30:00 AM »
Chick, I will try to keep an open mind about this as I could only see it being possible in a black interior car only, otherwise that car has had them changed sometime in the past. I would like to see the cast numbers from the backs of each handle.......................RatPack................
Troy, the car is a local 2 owner car with black standard interior. Guess I might be able to check the cast #'s with a mirror!
rat pack
« Reply #18 on: July 27, 2012, 02:38:56 PM »
Chick, more than likely they will have the "291" handles. I would still like to see other 68's that are unrestored before saying they got the later style knob. As this would be the very first 68 with this style knob..............RatPack.............
rat pack
« Reply #19 on: July 27, 2012, 02:55:39 PM »
I dug through all of my handles and found that the backs of the handles were no way to identify whether they were service replacements or not as the recessed cavity was different on just about all of them in some way or another. Here are some pictures showing differences in the 68-69 #9715291 (frt & rr 68, frt 69)handle, and the #9717838 rear handle for 1969 Camaros. There is one picture showing the original handles along with a repro handle that either came from the "HELP" rack at the parts store, not really sure where it came from, just marked CP on the rear. I did not get measurements showing the amount of offset for each as I am pressed for time today. I will be back on here Monday, earlier if I find the time............RatPack......................
« Reply #20 on: July 28, 2012, 12:15:05 AM »
Will try and get back over to the 68 survivor asap.
Here are some pics of a 68 291, 69 291, and late 80's/early 90's service replacement.
rat pack
« Reply #21 on: July 28, 2012, 02:06:11 PM »
Chick, that 20322800 handle was used on 83-88 G-body cars, and numerous other GM cars during the early 80's to late 90's. Wonder if that is the one that was a supercede for the correct handles. I cannot see it working in a Camaro due to the curvature of the handle..........RatPack...............
Lane 68
« Reply #22 on: July 28, 2012, 03:05:36 PM »
Rat Pack...
My understanding is the "800" handle has been superceded twice and is still avaliable from GM .
It has the run"deep curve" in it.
Lane
Lane 68
« Reply #23 on: July 28, 2012, 03:35:51 PM »
Chick / Rat Pack..
See Ed Bertrand's post previously in this topic.  I believe that is the superceded deep curve crank you speak of.
part number 20348200.
Hope this helps.
Lane 68
« Reply #24 on: July 28, 2012, 04:11:25 PM »
Geez, what a pain in the @$$. I'm sure glad I have power windows!!
 ;D
Ed "Bert" Bertrand
email me!
IZRSSS
  • Guest
« Reply #25 on: July 28, 2012, 04:49:34 PM »
 ;D
No $hi+! But don't ya know; someone, somewhere, has found a way to do the same with them ???
rat pack
« Reply #26 on: July 30, 2012, 03:26:32 PM »
Guys I verified that the 20348200 handle shown is still the same one available through GM and all of the aftermarket vendors. It is not correct for any 67-69 Camaro, and it may hit the molding on the rear panels, will have to check fitment first............RatPack............
« Last Edit: July 30, 2012, 04:23:03 PM by rat pack »
camarokidcal
« Reply #27 on: February 23, 2018, 09:41:15 PM »
In am redoing a 1968 Camaro Lemans Blue with Medium Blue Deluxe interior what color window cranks should I have? Blue or Black
luv2sixty9
« Reply #28 on: February 23, 2018, 09:48:28 PM »
Camarokidcal,
They should be blue as well as the door lock knobs
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
camarokidcal
« Reply #29 on: February 23, 2018, 09:50:25 PM »
Thank You
