June 19, 2013, 08:51:12 PM
Search:     Advanced search
83207 Posts in 10595 Topics by 4407 Members
Latest Member: georgeshaw
+  CRG Discussion Forum
| |-+  Decoding/Numbers
| | |-+  Broadcast Sheet Decoding
« previous next »
Pages: [1] Print
Author Topic: Broadcast Sheet Decoding  (Read 2127 times)
daytho1
Member
View Profile WWW Email
« on: June 24, 2006, 05:36:53 AM »
I have one of the original body broadcast copies for my 67 L6 that is in immaculate condition.  However, I don't see a lot of corrilation between the coding on the broadcast copy and RPO codes.  While I can figure out most of the coding based on what I have that I know is original, should these codes mean something to me or only to the factory?  Is there a code somewhere separate from the RPO codes that I should be looking at?
http://home.bellsouth.net/p/s/community.dll?ep=331&folderid=245269&groupid=306096&folderview=thumbs&ck=
« Last Edit: June 24, 2006, 05:39:50 AM by daytho1 » Logged
67 250, Bolero Red, N25
Check Out My Restoration Pages: http://home.bellsouth.net/p/s/community.dll?ep=16&ext=1&groupid=306096&ck=
CRG Member
View Profile Email
« Reply #1 on: June 24, 2006, 12:48:14 PM »
You won't find much on a broadcast copy that matches up directly with any RPO sales codes; those blocks simply contain number or alpha codes to identify specific part numbers of individual parts which that particular car required as it went down the line. After 1970 or so, the format changed completely, and it had all the RPO codes printed at the bottom.
Logged
daytho1
Member
« Reply #2 on: June 24, 2006, 12:56:04 PM »
Is there anything anywhere that you know of that would break down a broadcast sheet?
Logged
x77-69z28
Hero Member
View Profile
« Reply #3 on: June 26, 2006, 11:21:30 PM »
WHERE DID YOU FIND YOURS. I LOOKED UNDER MY BACK SEAT AND UNDER THE CARPET, BUT NO LUCK
Logged
69 x77 burnished brown, 711 int 05A bought in 78
67 rs/ss 350 butternut yellow 4 speed 2nd owner
11 cts-v blk diamond  edition wagon 556hp sick!
daytho1
Member
« Reply #4 on: June 27, 2006, 01:53:59 AM »
Found it several years ago behind the back seat when I removed it to have some upholstery work done.  They're scarce but I guess I was just one of the lucky ones.
Logged
gro51
Member
68 SS/RS 350
View Profile
« Reply #5 on: June 27, 2006, 08:50:10 PM »
x77-69z28 - I've never found mine either, but I've heard of them being found:
on top of the gas tank below the trunk floor (you'd have to drop the gas tank)
inside seat springs
behind rear seat
behind door panels
behind sail panel
under carpeting
tucked up & under the dash
Does anyone know of other locations to look?
Like daytho1 says, you'd be very lucky to find it.  They're usually long gone if you're not the original owner.  GOOD LUCK!
Logged
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
Rich
CRG Coordinator
68 L30/M20 RS
« Reply #6 on: June 28, 2006, 07:15:34 AM »
Kurt might have some info that would help you.  That he hasn't replied is a sign he's busy doing something. If he doesn't reply to this thread eventually send him a note. Rich
Logged
68 L30/M20 RS
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.101 seconds with 18 queries.
