Author Topic: M21 shifter linkage grommets  (Read 5812 times)
wisemanz28
« on: September 16, 2011, 09:20:03 PM »
I'm looking for the rubber grommets that the shifter rods go into on my muncie shifter linkage. I can't find them anywhere. Does anyone know of a good place to buy them?
IZRSSS
  • Guest
Re: M21 shifter linkage grommets
« Reply #1 on: September 16, 2011, 10:11:24 PM »
You might try these guys...It's in PDF format so give it time to load:
http://www.drclassic.com/images/catalogs/pdf/Camaro/Transmission.pdf
m22mike
« Reply #2 on: September 16, 2011, 11:59:00 PM »
If you are talking about a OEM Hurst shifter that originally had molded in place vibration isolators, try Pete at Presision Pontiac. Scroll down.
http://www.precisionpontiac.net/Products.aspx
If it is a aftermarket shifter Summit Racing has steel or nylon bushings for those.
http://www.summitracing.com/parts/HUU-3327302/
wisemanz28
« Reply #3 on: September 18, 2011, 06:29:59 PM »
Thanks so much guys, I've been looking for these grommets a long time.
JoeC
« Reply #4 on: September 20, 2011, 12:06:20 PM »
the 1970 and up replacement rubber bushing insert , you can still get from Chevy.
It was used for many years on all types of applications.
Many use the insert to restore 1969 shifters but 1969 originally used a molded on rubber bushing
TEAMMUNCIE
« Reply #5 on: December 24, 2011, 01:51:04 AM »
do you have a part number on those grommets?
