Author Topic: factory 1969 12 bolt pinion angle  (Read 34173 times)
mark x22
Re: factory 1969 12 bolt pinion angle
« Reply #15 on: December 04, 2010, 05:06:37 PM »
I redrew the spring in post 10 . When you set it up just get the 6 degree difference between the pinion and the spring perch as shown in the first drawing . Don't worry about the ground or the car that could vary with ride height . Just make it look like the drawing .
hdptsr
« Reply #16 on: December 05, 2010, 09:59:51 PM »
Thank you all for your input!  It makes sense to me now.  Even though the perches are welded on the axle tubes at a pinion angle of 6 degrees up, when the rear end is on the springs and installed, it is closer to neutral or 0 degrees.  That last drawing was excellent.  Does the assembly manual show all of this?  I better get me one.  Thanks for saving me tons of time and a headache later on.
mark x22
« Reply #17 on: December 05, 2010, 10:18:51 PM »
No those are my drawings .
« Reply #18 on: December 06, 2010, 04:26:29 AM »
And they are great drawings Mark! Thanks!
« Reply #19 on: December 06, 2010, 09:54:25 PM »
Yes, they are! Nice work!
« Reply #20 on: January 07, 2011, 05:57:38 PM »
Mark, post the pictures again. They're no longer showing up. It's good reference material to have!
mopar346
« Reply #21 on: January 08, 2011, 02:45:44 PM »
I saved a couple. Here ya go.
« Last Edit: January 09, 2011, 04:42:12 AM by KurtS »
mark x22
« Reply #22 on: January 08, 2011, 03:19:07 PM »
mopar346 you might want to delete the first one , the spring is wrong . this one is better .
[Fixed - Kurt]
« Last Edit: January 09, 2011, 04:43:05 AM by KurtS »
« Reply #23 on: January 08, 2011, 06:38:58 PM »
Perfect. Thanks!
mopar346
« Reply #24 on: January 10, 2011, 02:15:34 AM »
Thanks for the update.
« Reply #25 on: March 13, 2023, 07:13:25 PM »
Did anybody save these images off in large size?
