Author Topic: DZ 302 engine A36990 VI010DZ  (Read 5944 times)
musclechief
« on: August 12, 2010, 05:51:21 AM »
DZ 302 is early date J 4 8 Block 386 front block pad: A36990 VI010DZ pistons 0.30 L 2210 a
crank 1178 needs repair . rods forged 8" balancer clock cover 11/69I don't have orig oil pan it comes with 7qt moroso .
Dunvo orig cam shaft, springs O rockers locks are good condition.Lt-1 valve covers are in good shape.
186 Heads are virgin 194 need to cut to 202 valve size. the are correct to date code for the 386 block.
67 Z28 intake manifold 3917610 is early also. have 3310 holly 780 CFM.
Dist. is for 1970 .350.
This engine needs to be rebuilt.
Re: DZ 302 engine A36990 VI010DZ
« Reply #1 on: September 08, 2010, 02:03:31 AM »
Does it have a VIN stamped on it? Could A36990 actually be part of the VIN? Should be 19N512121 or such.
