Author Topic: 68 Z28 01B- Which water-pump bypass, the hex or square head?  (Read 8642 times)
One of the items not on our 68 Z28 01B built when purchased was the orig. water pump with the 90 degree bypass. Realize 67 Z's and early 68's had the hex head type fitting and then it was changed to a square head design. For our 01B which one would be correct and when did they make the change?
Jerry@CHP
Re: 68 Z28 01B- Which water-pump bypass, the hex or square head?
« Reply #1 on: July 18, 2010, 02:55:04 PM »
This has been updated.  All use the hex fitting,
Jerry
« Reply #2 on: July 19, 2010, 02:28:14 AM »
So the square one is not correct for any 68 Z?  I swear I saw a pic of one in your book.
fireZ
« Reply #3 on: July 19, 2010, 11:59:26 AM »
I put a square one on my 02E car. I did see the same picture in my book. Who knows GM may have ran out of stock at one time and maybe changed over from a hex to square fitting for a short while. I am sure they would not stop building cars if they ran short on one small part.
1968 Z28 LA Built
LIC # RPO Z28
« Reply #4 on: July 19, 2010, 10:46:49 PM »
I've got a hex one, but by the book I bought a square one and was going to change it out.  I'd rather not do that if I didn't have to.
« Reply #5 on: July 21, 2010, 10:06:15 AM »
I assume you did not have the orig. water pump if considering changing to the sq bypass???? And since the time frame for change was up in the air (at one time) I'd forget the change. I gotta obtain a hex one and glad I did not purchase a sq. one immediately. We ought to do a survey of our fellow 68 Z/28 owners just to see if anyone had the orig. water pump (what bypass) but sure Jerry has seen plenty.
« Reply #6 on: July 21, 2010, 04:29:38 PM »
The original water pump bypass elbow on my 02C '68 Z/28 has the hexagonal head.
« Reply #7 on: July 21, 2010, 10:23:45 PM »
Mine's an 05D which puts it in the realm of being after most of the mid-year changes.  Mine is one in the window of having left-over 67 front end parts on it.  Jerry's comment was "all use hex fitting".  So where did the pic come from?
