Author Topic: what determined the replacement for a CE block  (Read 5488 times)
GI JOE
« on: March 13, 2010, 07:14:07 PM »
3) What determined the service replacement... i.e. Cracked block seems obvious, but what about a rod bearing? would they rebuild it?
SFC GI JOE - Airborne Paratrooper
68- L-78, M22, BV
69- L-78, M22, BV, Conv
Re: what determined the replacement for a CE block
« Reply #1 on: March 14, 2010, 02:40:06 PM »
Generally, if the failure involved damage to the block (thrown rod, broken piston, dropped valve, broken crank, etc.), a new short block was installed.
Jrschev
« Reply #2 on: March 15, 2010, 09:08:41 PM »
John is correct. If there was any damage to the block it was replaced. But in most cases the service rep gave the green light for an entire short block to save warranty time. It was usually an easy sell to get the rep to go this way and it was usually better for the customer as well. I've seen short block assemblies replaced because of a noise that could not be isloated. Seems hard to believe but again it was many times based on warranty time paid versus cost of replacement parts.
1969 Z11 Pace Car (05A) 350/300 L48 4-Speed
