Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
power steering leak
« previous
next »
Print
Pages: [
1
Author
Topic: power steering leak (Read 8329 times)
68crossram
Newbie
power steering leak
on:
November 15, 2009, 10:24:29 PM »
I've got a 67 Camaro with a stock engine compartment with the 350. I have been leaking power steering fluid from behind the pump. I think it is coming from the pressure line. Thought it was from the nut where the line attaches to the pump, I tightened it. Still have the leak. I'm sure this is an aftermarket hose from a reputable supplier. Any thoughts on other sources to check?
Tweet
Logged
hotrod68
Hero Member
almost finished
Re: power steering leak
Reply #1 on:
November 16, 2009, 08:23:41 AM »
It sounds simple, but I'd check to make sure the nut isn't cross-threaded and the flare is seated fully onto the pump nipple. If it isn't, the fluid can climb the threads and seep out. Just a thought and good luck!
Logged
HotRod'68 1968 SS350 coupe undergoing frame-off resto/rod. 386/350/4.11s
Butternut Yellow black standard interior
Hero Member
Reply #2 on:
November 16, 2009, 11:23:31 AM »
There is an O-ring on the fitting that screws into the back of the pump. Rebuild kits are available OTC.
Logged
Stingr69
Hero Member
Reply #3 on:
November 25, 2009, 01:49:51 PM »
A pump overhaul is fairly easy. The pulley may require a special tool but they are available to borrow for free. A little heat can get it off if you are carefull. You may be leaking between the pump and the resevoir. Buy the inexpensive overhaul kit and have a go at it.
-Mark.
Logged
68crossram
Newbie
Reply #4 on:
December 14, 2009, 02:44:23 AM »
Thank you for your replies, seems the new power steering hose was faulty, leaking at the crimped end.
Logged
Print
Pages: [
1
« previous
next »
Maintenance
power steering leak
