Author Topic: dip stick broke off inside motor  (Read 5498 times)
alanhowell
« on: November 04, 2009, 08:18:55 PM »
The lower portion of the dip stick broke off inside the engine @ the full mark. Could this get inside the motor & cause damage or should I assume that it is laying in the bottom of the pan and not worry about it? Looking foe suggestions.
tom
    • Discount Internet Services
Re: dip stick broke off inside motor
« Reply #1 on: November 04, 2009, 09:54:02 PM »
I don't know, but it would worry me. Can you pull it out the drain plug hole with a magnetic or other tool?
69 X11 Z21 L14 glide
o
alanhowell
« Reply #2 on: November 05, 2009, 01:37:13 AM »
That will be my next step with a magnet on a flexible tube. My last resort will be to drop the pan if the magnet doesn't work I guess.
blownonfuel
« Reply #3 on: November 05, 2009, 09:20:17 PM »
If it was my engine I'm sure it would end up between a rod and the crank and ruin everything.  I would make sure I got it out. I would not be able to sleep knowing it was in there.
fiveforty
« Reply #4 on: November 05, 2009, 10:01:09 PM »
If you get a few different magnets and do some fishing around you should get it out with no problem. Goodluck.
