Author Topic: Need Help  (Read 6849 times)
Lenny
  • 68 LeMans Blue Sport Coupe
Need Help
« on: October 13, 2009, 03:49:24 PM »
I have a 68 with a Base 327/210 Engine. I believe the original 2bl (Rochester ?) was replaced with a Holley 2bl and after market air cleaner. The car has been out of commission for a long time and some of the parts have disappeared. I'm trying to go back to an original set-up with the Rochester. Can anyone furnish me with photo's or info on the correct set-up for the Original Air Cleaner and Vacuum lines. Appreciate it....
Lenny   ???
Lenny - Numbers Matching
Other Ride - -
62 Chevy "Biscayne"
2dr Post - BB
68Zproject
Re: Need Help
« Reply #1 on: October 14, 2009, 12:09:55 AM »
http://www.camaros.org/carb.shtml#roch  That's all I could find with time I had.  I'm sure there is more and someone will know.
68Z28
Re: Need Help
« Reply #2 on: October 14, 2009, 03:07:43 PM »
Do you have the '68 Camaro Assembly Manual? If not, that will be a big help as you work on the car.
Lenny
Re: Need Help
« Reply #3 on: October 14, 2009, 06:24:23 PM »
I do have a "copy" of the assembly manual, but it's very vague and leaves you guessing in a lot of area's. Thanks..I appreciate the info. I did check out the link.
Other Ride - -
62 Chevy "Biscayne"
2dr Post - BB
lakeholme
  • 68-12D L30/M35
Re: Need Help
« Reply #4 on: October 14, 2009, 09:31:36 PM »
Just sent you a PM with another view on several 68 motors besides what the AIM shows... but if the AIM does not help, not sure this will either.
It might help if you would break down what you are trying to figure out into individual questions.
sebastien
Re: Need Help
« Reply #5 on: October 14, 2009, 10:59:52 PM »
I will send you pictures, let me know if you need more.
Sebastien 68  327 rag top
