Author Topic: Removal of Rocker Panel Spears  (Read 4936 times)
rockphil
« on: August 01, 2009, 04:50:49 PM »
What is the correct procedure to remove rocker panel spears from a 69 camaro?  What type of clips are used?
Mark
Re: Removal of Rocker Panel Spears
« Reply #1 on: August 02, 2009, 12:07:14 AM »
Its one big long clip about 2/3 the length of the door.  Remove the two screws on the underside or the molding, then put a screwdriver in one of the bottom side water drain slots and pry upward once the spear starts to come off the clip just work your way down the length of the spear till it pops completely off.  Protect you paint as you see fit.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
