Author Topic: carb heat shields  (Read 13579 times)
ccargo
carb heat shields
« on: March 27, 2006, 09:40:58 PM »
I've noticed these ugly carb heat shields being advertised for both Rochester and Holley applications. Were these ugly things ever used on first generation camaros?
67 O-1 O4A L35 Convertible, Indy Zone IPC
Re: carb heat shields
« Reply #1 on: March 27, 2006, 10:17:38 PM »
Not from the factory, but they could be purchased over the counter. I bought one in the early 70's for a 57 Chevy I was building. It was cool looking then. Not really sure how much it helped.
I've also been told they were standard on the ZL1's, but that's only hearsay.
Anyone else??? JohnZ???
« Last Edit: March 27, 2006, 10:30:18 PM by bertfam »
« Reply #2 on: March 28, 2006, 06:07:12 PM »
As far as I know, they were never factory-installed, but many were dealer-installed under TSB's for warranty complaints of fuel percolation and vapor lock.
nuch_ss396
« Reply #3 on: March 28, 2006, 11:13:27 PM »
John,
That matches what I've heard over the years.  One other was they were a California car thing.
Just for kicks & giggles, there was a topic on the NCRS.org site about a 1970 tri-power 427 Corvette engine ( designated he LJ-2 )
that never was due to production problems.  One member reported he has an original tri-power heat shiled destined for this car.
If the shield wasn't going to be producction based, why would it exist as a service item even before the car was built?
Steve A.
« Reply #4 on: March 29, 2006, 03:18:03 PM »
The LJ-2 was going to use the same tri-power intake carbs and spacing as the 427 tri-power on the L-71; it's not clear that the shield was only for the LJ-2.
gro51
  • 68 SS/RS 350
« Reply #5 on: March 29, 2006, 05:36:17 PM »
I replaced a rochester q-jet on my 68 ss 350 (L48) a few years ago.  I forgot to put the heat shield on.  Fuel percolation problem BIG TIME.  Removed the carb, installed the heat shied and the problem was completely fixed.  As far as being ugly goes, you can barely see it under the carb if you're using the correct one.
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
nuch_ss396
« Reply #6 on: March 30, 2006, 10:28:52 PM »
We're not talking about the same thing here.  The heat shield being discussed here was aluminum and quite large.  It was much wider and longer
than the carb base.  It covered a large portion of the intake runners.
Steve A.
nuch_ss396
« Reply #7 on: March 30, 2006, 10:31:15 PM »
John,
Are you saying that the heat shield could have been an L-71 service item as well?  They already existed in 1969 as service items, didn't they?
My Vette knowledge is limited.
Steve A.
« Reply #8 on: March 31, 2006, 06:29:46 PM »
I've never seen one on a car - have only seen a photo of one alleged to be a service TSB part.
