Author Topic: 68 SS temp sensor  (Read 6385 times)
My68SS
68 SS temp sensor
« on: June 22, 2009, 09:53:24 AM »
Hi Crew, been a while since my last visit. Multiple issues keep dragging me away from the only issue that really matters - my Camaro!!  :)
What's the correct p/n for the temp sensor for '68 396 with console guages. My parts book is not totally clear on this.
Also, is the connector a straight push-on round bullet style, or a clip that pushes on at right angles to a flange at the end of the sensor pin?
Cheers.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
Re: 68 SS temp sensor
« Reply #1 on: June 22, 2009, 03:39:07 PM »
I don't know about BB, but I would assume they are all the same.  I just bought one from Lectric and it has the straight, push-on, round pin connection.
My68SS
« Reply #2 on: June 22, 2009, 05:07:00 PM »
Yeah that's what's on mine atm, just a straight round pin, no flange, just a small groove about half way down the connector pin for the clip to snap into.
According to my parts book, this one pictured below is for 67 models and has the flanged pin, p/n 1513321
Group 1.150 in the 65 - 69 PnA is very confusing to decode  ???
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #3 on: June 22, 2009, 06:12:44 PM »
Rob -
My '69 P&A list part number 6400759 for your application.
A quick search on Google resulted in this...
http://www.corvette-paragon.com/p-354320-temperature-sender-switch.aspx
Below are some photos of an original unit...
« Reply #4 on: June 22, 2009, 06:33:19 PM »
That's what mine looks like.  Most of the supply houses get them from Lectric and you can order direct from them.  The only problem is they ship UPS so if that's all you order you pay 9$ for shipping a small part.
My68SS
« Reply #5 on: June 22, 2009, 07:17:30 PM »
That's the one! Thanks guys :)
Mine still works ok but ages ago I bent the pin almost to the point of breaking off - not paying attention rolling the head over with it still screwed in!
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
