Author Topic: Engine VIN location  (Read 8567 times)
silver69z22
Engine VIN location
« on: April 23, 2009, 04:08:01 PM »
Hi Guys.
  My 69 RS has the partial vin # and suffix code on the front of the engine block behind the altirnator. The build date is 12-B 1968 and the vin # is 124379L513112. some research says it should be by the oil filter, not so on my car. Just wanted to share the info. have a good day,
steve
Re: Engine VIN location
« Reply #1 on: April 28, 2009, 02:50:05 AM »
The location bounced around at LA. http://www.camaros.org/drivetrain.shtml#partialVINs
But your location is common for that timeframe.
What's the work order # on the cowl tag (e.g. A123, on the same line as the build date)?
What's the engine code?
Thanks!
Bdblu
« Reply #2 on: May 03, 2009, 07:02:12 PM »
My Z28 is a 12B build as well, I found the casting# and casting date but had a difficult time finding the vin.  I can vouch for not finding it near the oil filter.  I the only numbers I found there were foundry numbers.  Was your car a Norwood or LA car?
silver69z22
« Reply #3 on: May 05, 2009, 12:37:17 AM »
Hey Kurt,
   the work order number is L 7 1 7   the engine code is V 1 I 3 0 F L   it's the 327ci   210hp  hey Bdblu my car is from the Van Nuys, Ca plant or L A   thanks for replies, steve
« Reply #4 on: May 05, 2009, 03:33:31 AM »
Thanks!
XRAM
« Reply #5 on: May 13, 2009, 12:22:10 PM »
Does the same hold true for Norwood cars (1969 that are 1968 build) that are 12B - VIN could be at either the pad or filter location? What about 12A cars?
« Reply #6 on: May 16, 2009, 04:59:22 AM »
No. NOR and LOS processes did not change at the same time.
XRAM
« Reply #7 on: May 16, 2009, 02:52:25 PM »
Hi Kurt
Where would a 12A Norwood built VIN be - on the front pad or oil filter area?
« Reply #8 on: May 22, 2009, 04:02:02 AM »
It normally should be on the pad.
