Author Topic: Ball Joint Lubrication Problem  (Read 6129 times)
stovebolt
  • 1968 L6 Sport Coupe
« on: April 24, 2009, 07:05:44 PM »
I recently replaced all four ball joints on my 68 coupe with TRW products. Three of the ball joints accept the new grease while purging the old grease. However, one of the ball joints will not purge out the old grease. The rubber boot swells as I pump in new grease but no old grease comes out. Any ideas as to what is causing this problem and suggestions how I might correct this? Thanks for any help provided. Joe.
Re: Ball Joint Lubrication Problem
« Reply #1 on: April 25, 2009, 02:15:08 PM »
Is the purge hole open in the boot?
stovebolt
« Reply #2 on: April 25, 2009, 07:14:33 PM »
The "bleed vent" as TRW calls it is located at the base of the dust seal. I installed the dust seal with the bleed vent facing inward as per the instructions. See the attached picture.
Since I noticed the problem, I haven't tried to correct it in any way.
