Author Topic: Rally wheel dating  (Read 29679 times)
bc69
Re: Rally wheel dating
« Reply #30 on: December 24, 2014, 06:04:55 PM »
Have yet for anybody to show a early DG with date. I have one other guy that also has DG rally's and he can't find any stamps either. His is also a early 67ss but from LOS plant
Brad
RSSS
L78 steve
« Reply #31 on: December 28, 2014, 04:28:06 PM »
The Clovin book states that the date stamping on Rally wheels started around 3/67. I have a 2/67.
There was a DG wheel discussion on this forum back in September:
http://www.camaros.org/forum/index.php?topic=12536.0
I've never seen a 67 model year DG wheel with a year stamp of 66, so I'm wondering if they just started that year & month stamp in January 1967?
69 Z/28 Dover White. SOLD
bc69
« Reply #32 on: December 28, 2014, 04:51:24 PM »
So yours are as mine Steve. DG and that's all?
Brad
RSSS
bc69
« Reply #33 on: December 28, 2014, 05:12:21 PM »
They are said to have gone from a single to the 2 letter code at the start of 67. I have found a reference to the DF wheel and it's coding starting 3/1/67. Also that the actual application date code would be on the outside of the wheel. All dates on the inside were manufacture dates for that part of the wheel stamped.
Brad
RSSS
bc69
« Reply #34 on: December 29, 2014, 02:50:11 AM »
So the question I guess should be, is this date code with the JJ between beads the same as the date code on the outside all other rally's? Is it the intended application date code?
Brad
RSSS
L78 steve
« Reply #35 on: December 29, 2014, 02:51:28 AM »
Correct if you are referring to the outside under the trim ring.
bc69
« Reply #36 on: December 29, 2014, 02:59:50 AM »
Yes Steve that's my question. If so then why with the DG and DF wheel? No others?
Brad
RSSS
L78 steve
« Reply #37 on: December 30, 2014, 01:40:43 AM »
The other wheel codes should follow suit meaning prior to 2/67 no date. I dont have any of the other early codes for proof.
pjbizjak
« Reply #38 on: December 31, 2014, 04:03:47 AM »
Late 67's and mid 68's Z/28 cars had a DF code by the valve stem(no date) and the DF was upside down(facing inward). The rightside up DF started mid to late 68 and into the 69 model year.
bc69
« Reply #39 on: December 31, 2014, 01:06:53 PM »
jak,
Where did you find this data? Also where would be best place to pass on mine? I have a early 67 w/DG rally's. They also face inward and are to the left of stem. No other stamping found without breaking tire.
Brad
RSSS
pjbizjak
« Reply #40 on: February 01, 2015, 03:37:51 PM »
IN Jerry McNeish's book.
