Author Topic: Suffer from Big Cam no Vacum!!  (Read 12623 times)
Da67Kid
« on: April 08, 2009, 12:50:57 AM »
Hi all I am Guss! Hi Guss !I suffer from Big Cam No VACUUM (LOL)
What are some of the electric vacuum setup people are using and with and info and pics would be good. i seen one not sure of make all billet and like a small box  about $450 I was looking for a low dollar cure There are so many vac pumps out there I though   I would ask. Thanks
hotrod68
  • almost finished
Re: Suffer from Big Cam no Vacum!!
« Reply #1 on: April 11, 2009, 02:38:25 AM »
Jeg's sells a nice little vacuum canister that will let you use your power brakes and doesn't require a pump. Might be worth a look. Good luck!
« Reply #2 on: April 11, 2009, 07:17:22 PM »
<<Jeg's sells a nice little vacuum canister that will let you use your power brakes and doesn't require a pump.>>
I used one of those on my tube-frame Grand Sport replica instead of buying a pump, and it worked out fine.
Da67Kid
Re: Suffer from Big Cam no Vacuum!!
« Reply #3 on: April 27, 2009, 12:05:40 AM »
I do not make any vacuum with the cam i run so I can not make any in a can from them . I am looking for a 12 volt one Other then the high dollar ones i keep finding. Thanks
Mark
« Reply #4 on: April 27, 2009, 10:45:22 AM »
You might not make any vacuum at idle but you will make vacuum at higher RPMs and on deceleration.  Install a can with a check valve beteen the can and the manifold any you'll be fine.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
ChevyThunder
    • Pro Racing
« Reply #5 on: May 29, 2009, 03:10:06 PM »
I have a big inch SB in my car with a roller cam with 4 wheel disc brakes. I had to put an electric pump in . It works well but the down side is when you put your foot on the brake you can hear that pump kick on and work and my car is loud and completley DynaMat'd . So if you can make it work with Mark's sugesstion then that would be great otherwise you can get this pump at Summit . I mounted it front drivers side and when looking straight on to the motor you can't even see it .
1969 X44 COPO
1969 X33 RS Z/28
Da67Kid
« Reply #6 on: June 07, 2009, 10:27:27 AM »
I did try the Can but does not work I also have a small aftermarket brake booster 4 wheel disc set up, will have to do a electric pump I guess.
sixt9x33rs
« Reply #7 on: June 21, 2009, 12:25:16 PM »
John that car is awesome. Do you still have it?
« Reply #8 on: June 21, 2009, 02:45:42 PM »
Nope, sold it in 1998 - needed the garage space for another project.
