May 26, 2013, 01:55:30 AM
Search:     Advanced search
82283 Posts in 10509 Topics by 4352 Members
Latest Member: NCCaprice
+  CRG Discussion Forum
| |-+  Originality
| | |-+  1969 radiator fan
« previous next »
Pages: 1 2 [All] Print
Author Topic: 1969 radiator fan  (Read 2825 times)
69houdini
Member
69 SS X55 Butternut Vert / 69 RS SS Coupe L48 /
View Profile Email
« on: December 15, 2008, 02:49:32 PM »
 Hey guys , I am taking off my dealer added air that was added on back when the car was P/U at the dealers in 69, they did a terrible job on it. I want it to be correct. Thing is it has a 6 blade non numbered fan and everything I read s/b a 4, 5 or 7 blade fan. I read about the non numbered fan but nothing was said about the 6 blades. Any insight or info you can give me would surely help. Thanks
Logged
Hero Member
View Profile
« Reply #1 on: December 15, 2008, 03:22:01 PM »
http://www.camaros.org/coolingsystems.shtml
Logged
69houdini
Member
View Profile Email
« Reply #2 on: December 15, 2008, 09:57:43 PM »
Hi Kurt,    Yes I read your report before I posted. I did do more digging and found the exact same fan on e-bay and in the Classic Industries catalog. They have been making this fan for a long long time. Your report lead me to what I really needed to be correct so a big thanks to you.  -John
Logged
69houdini
Member
View Profile Email
« Reply #3 on: December 15, 2008, 10:15:40 PM »
Sorry Paul, I meant to thank you but had Kurts report on my mind. Must all 7 blade fans have clutches?
Logged
CRG Coordinator
View Profile Email
« Reply #4 on: December 16, 2008, 10:49:45 AM »
In 69, all 7 blade fans have clutches in Camaros.
Logged
Pacecarjeff
Member
View Profile WWW
« Reply #5 on: December 16, 2008, 10:13:29 PM »
The 6 blade fan is very common for Pontiac, Cadillac, Buick, and Olds.
It was used on many A/C cars in the 60's and 70's.
For those manufactures -- it was their High Perf fan.
Chevrolet never used a fan with 6 blades back then.
Logged
srode
Member
View Profile Email
« Reply #6 on: April 17, 2012, 04:07:05 AM »
So from reading the article a 69 pace car without AC and with a 350 should have a 4 blade fan and not a clutch fan?
Logged
Steve - 02D Z11 and a Plain Jane hardtop
CRG Coordinator
View Profile Email
« Reply #7 on: April 17, 2012, 12:05:32 PM »
More than 97% of  SS's had the 4-blade fan.
Logged
srode
Member
View Profile Email
« Reply #8 on: April 17, 2012, 08:27:57 PM »
thanks Kurt, I wouldn't have guessed that , but after reading this post suspected - nice to have confirmation.
Logged
CRG Coordinator
View Profile Email
« Reply #9 on: April 17, 2012, 09:22:40 PM »
Good point, I can add that clarification to the article.
It does say "So yes, your SS350 or SS396 (325hp or 350 hp), if without AC, likely came with the standard four-blade fixed fan. " But it will be clearer with percentages.
Logged
Pacecarjeff
Member
View Profile WWW
« Reply #10 on: April 20, 2012, 08:17:07 AM »
Unless the HD cooling option was ordered - there were a good number of SS350 cars that had a clutch fan.
Check your radiator code before assuming...
Logged
srode
Member
View Profile Email
« Reply #11 on: April 20, 2012, 06:41:21 PM »
Are the blades on the original clutch fans steel or aluminum?  Not the center hub but the blades.
Logged
CRG Member
View Profile Email
« Reply #12 on: April 21, 2012, 10:49:53 AM »
The blades on the "772" fan are aluminum; don't know about the others.
Logged
Pacecarjeff
Member
View Profile WWW
« Reply #13 on: April 21, 2012, 03:35:05 PM »
5 blade Camaro fans have steel blades.
The 4 blade fans don't really have "blades" - the unit is steel stamped in two parts and riveted together.
Logged
Hero Member
View Profile
« Reply #14 on: April 21, 2012, 04:02:35 PM »
And yes.....those steel blades sure play havoc on timing light cables  Grin
Logged
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
srode
Member
View Profile Email
« Reply #15 on: April 21, 2012, 08:21:17 PM »
did the use aluminum on the 7 blade fans to keep the weight down so they didn't come apart at higher RPMS like the 302 was capable of I wonder?
Logged
CRG Coordinator
View Profile Email
« Reply #16 on: April 25, 2012, 02:20:47 AM »
HD cooling had no affect on the fan. "The V01 HD radiator option did not affect the fan usage."
http://www.camaros.org/coolingsystems.shtml#fan
Out of 400,000 non-AC V8 cars that could have the optional clutch fan ordered, only 1% of them had the option. Even if most of these clutch fans were installed on non-L78 SS cars (not very likely), under 5% of those SS cars would have them. So yes, your SS350 or SS396 (325hp or 350hp), if without AC, likely came with the standard four-blade fixed fan.
Steve,
The aluminum is to keep the rotating mass down.
Logged
srode
Member
View Profile Email
« Reply #17 on: April 25, 2012, 03:44:17 AM »
Thanks Kurt, I figured to keep the rotating mass down - but why would that be important?  Is it to let the speed of the fan come up to the engine speed quicker and so put less strain on the clutch?  Is it to help the motor rev quicker?  Keep centrifical forces down so the fan stays together at high RPMs?  I realize this was a design choice by engineers and answers may be speculation, those are the only 3 reason's I could come up with but thought someone might know for sure which is why I was asking.
Logged
Pacecarjeff
Member
View Profile WWW
« Reply #18 on: April 25, 2012, 12:42:19 PM »
Except that a clutch fan on an SS-350 would much more likely to be original equipment on a HD cooling car.
If I saw a clutch fan on a standard cooling car - I would be more suspect to the originality.
My 69 SS-350 has HD cooling with an original 7 blade clutch fan. I believe it to be completely original to the car.
Kurt, remember you pointed that out to me when i first got my car - I did not originally believe a clutch fan was possible?
After close examination of the dates on Radiator, fan clutch, and fan blades - I was convinced.
Logged
CRG Coordinator
View Profile Email
« Reply #19 on: April 30, 2012, 11:23:32 PM »
Good point - the options were not tied together, but if someone was thinking to order one option, there's a higher probability that they might order the other one too.
I've seen that often on customer ordered cars.
Logged
crobjones2
Member
View Profile
« Reply #20 on: May 03, 2012, 08:51:45 PM »
I also have a 7 blade fan with HD cooling(3 core)- Factory AC
Although I am a little confused about the radiator - ?F and IH tanks on a L48 auto w/AC? ?= there is a repair shop tag soldered/brazed over the letter
Logged
Chris
69 SS 350
tmodel66
Hero Member
View Profile Email
« Reply #21 on: May 03, 2012, 09:18:17 PM »
Wouldn't it be the OF tank?  Have you looked at the tank application chart?
http://www.camaros.org/coolingsystems.shtml#application
Logged
Daniel
crobjones2
Member
View Profile
« Reply #22 on: May 03, 2012, 09:44:23 PM »
That would be my assumption as well, but the application chart has the OF tank excluded from L48/auto/C60 applications
Logged
Chris
69 SS 350
CRG Coordinator
View Profile Email
« Reply #23 on: May 05, 2012, 11:59:17 PM »
Chris,
That exception is for 67-68.
> (exc 67-68 L30/L48 w/ V01 or AC)
I'd say you have AC - which included the 7 blade fan and a larger radiator.  Wink
Logged
srode
Member
View Profile Email
« Reply #24 on: May 06, 2012, 06:24:50 AM »
Well I found out why it's important to keep the rotating mass down - belt slip.  With an all steel blade with more blades the fan will slip on a fast reving engine.
Logged
« previous next »
Jump to:
Page created in 0.096 seconds with 17 queries.
