Author Topic: 1967 heater core  (Read 8379 times)
mjbake
1967 heater core
« on: December 02, 2008, 05:33:31 PM »
I need to replace the heater core on a '67 RS Convertible no a/c. The shop manual says I need to remove the fender. Are there any short cuts anyone knows of. I really do not want to remove the fender. I am hoping I can just lower the inner fender enough to get the heater core out.
67 L30/M20
Convertible
Re: 1967 heater core
« Reply #1 on: December 02, 2008, 07:54:46 PM »
The heater core is replaced by removing the inside heater box (inside the car); all you need to do in the engine compartment is to remove the nuts from the inside heater box studs that protrude through the blower housing flange. See the '67 Chassis Service Manual, page 1A-4 and 1A-5. The fender or skirt removal is only necessary if you need to remove the blower motor (page 1A-3).
mjbake
« Reply #2 on: December 02, 2008, 09:28:28 PM »
Thanks, I look a little more forward to tackling the job now.
67 L30/M20
Convertible
