Author Topic: Steering Box decode needed  (Read 5080 times)
sdkar
« on: September 13, 2008, 12:15:50 AM »
I have a power steering box I pulled from a 68 Camaro in a junkyard.  The number on the case is 5691676 and 36 underneath that.  The date stamped on the top is 255 8.  There are some other numbers but I don't think they are relevant to determining the box's origin.  If other numbers are needed, post it here and let me know and I will add them.
If I remember correctly, this would indicate the 255th day of 1968...Correct?  This would give me a rough date of Sept 12, 1968.  That would make this an early 69 Camaro box instead?  Just want confirmation because I am going to list it on ebay and want to make sure I represent it correctly.  Also, what other vehicle would this box be correct for?  Chevelle, Nova,...?
sdkar
Re: Steering Box decode needed
« Reply #1 on: September 13, 2008, 02:15:38 AM »
Okay...I cleaned up the cap better and it is hard to see if the number after the 255 is an 8 or a 3.  (It could have been a lightly tapped 8)  The day stamped on the case is 249.  Is there a way to tell what year the casting was done?
