Author Topic: Engine Type of 67 Camaro  (Read 6186 times)
Mr.Kane
« on: August 22, 2008, 05:22:33 PM »
Hi there,
i'm going to buy a 1967 Camaro RS coupe.
I know that the engine has been changed and was now wondering which engine would be there correct one.
I provided the cowl tag to take a look.
It has now code for a engine type, so it should be the LF7 with the 327/210hp.
But, this is an export car, it was driven in chile 20 years ago.
Is it possible that this car was equipped with the 283ci/195HP export V8 ?
The dealer here in Germany has this engine in his warehouse, too.
If this would be a possbile original engine i think it would be great to buy it for the car.
Thanks for your help!
Jan from Germany
hotrod68
  • almost finished
Re: Engine Type of 67 Camaro
« Reply #1 on: August 23, 2008, 04:30:24 AM »
Can't speak for an export, but no domestic Camaro ever had a production 283. Good luck!
RAfbody
« Reply #2 on: August 23, 2008, 04:34:44 PM »
What is the stamp on the front pad on the engine block from the motor in his warehouse?
Russ
lakeholme
  • 68-12D L30/M35
« Reply #3 on: August 23, 2008, 06:38:25 PM »
And when you negotiate the price of the car, point out the cowl tag has been removed and put back on with a screw and a bolt...
That makes its originality hard to verify and reduces the value of the car.
« Reply #4 on: August 23, 2008, 06:46:51 PM »
The 283 was only for Swiss cars.
It would have had either 327 - LF7 or L30.
