Author Topic: 69 Z28 brake problem.....hanging up  (Read 10102 times)
lcmc
« on: July 24, 2008, 04:59:07 PM »
My brakes on my Z want to hang up after car is driven a few miles. I noticed that the pedal is tight and if you put you foot behind the pedal and pull back it will relax the brakes some. Car does have a new reproduction booster on it. Is there some kind of adjustment I need to make?
Danny
1969 Z/28 X77
fireZ
Re: 69 Z28 brake problem.....hanging up
« Reply #1 on: July 24, 2008, 07:57:21 PM »
Do you know if you have the correct brake booster rod in the car? I know there are a couple different sizes.
1968 Z28 LA Built
LIC # RPO Z28
lcmc
« Reply #2 on: July 24, 2008, 08:00:14 PM »
It's the one that came with the booster and master cylinder.
Danny
1969 Z/28 X77
« Reply #3 on: July 24, 2008, 08:18:15 PM »
Check rod length and adjust if neccessary. Are all 4 hanging up and if not which one or ones are?  Scott
lcmc
« Reply #4 on: July 24, 2008, 10:35:31 PM »
I adjusted the rod going to the pedal, plus the brake light switch. Took it for a test drive and everything is fine. I believe it was the switch more than anything.
Danny
1969 Z/28 X77
« Reply #5 on: July 25, 2008, 03:23:03 PM »
The booster-to-pedal pushrod always needs to be adjusted to ensure you have free play at the top of pedal travel, to avoid just the symptom you describe.
