Author Topic: 69 Center axle bumper - two styles?  (Read 8630 times)
copo
Re: 69 Center axle bumper - two styles?
« Reply #15 on: January 01, 2024, 07:21:36 PM »
my old 05E X77 Norwood had the bolt in style, my 06A X44 Norwood has the bolt in style
Dave69x33
« Reply #16 on: January 02, 2024, 04:30:22 PM »
Updated list with the info folks have provided so far. I included the CRG contributor to keep from duplicating input. I did not include the X-code of the '69 Camaro assuming it did not effect the body construction and use of the center axle bumper (snubber) usage. We will have this CRG thread to look back on to see that Camaro build type info.
01B, NW, push in Iowa Jon
02D, NW, push in, from RikerZ28
04C, plant? push in, from L78 steve
June, VN, bolt in, from KevinW
05A, NW, push in, Dave69x33
05A, NW, push in, from Iowa Jon
05E, NW, bolt in from copo
06A, NW bolt in, from copo
08E, NW, bush in, from x66 714
09D, NW, push in, from R68 GTO
169INDY
« Reply #17 on: January 02, 2024, 06:22:41 PM »
04C, VN, Push In, from 169INDY (Z11)
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Dave69x33
« Reply #18 on: January 03, 2024, 04:33:12 PM »
Thanks Jim (169INDY)!
Updated list:
04C, VN, push in, from 169INDY
HOT3O2
« Reply #19 on: January 03, 2024, 11:42:28 PM »
12B, VN, Push In, From HOT3O2
Rick
69 RS/Z28
x77-69z28
« Reply #20 on: January 04, 2024, 01:40:47 AM »
My 05A Norwood Z/28 that I have owned since 1978 has the bolt in.
Buddy
Badshifter
« Reply #21 on: January 04, 2024, 03:03:32 AM »
Norwood 09C (late) push in, holes are there but have no threads or sign of past bolts.
1969 Z28 X77 09C
« Reply #22 on: January 04, 2024, 03:20:12 PM »
If you are keeping track, I think it would be important to know if the car has a 12 bolt or 10 bolt and the axle ratio.
Dusk Blue Z
« Reply #23 on: January 04, 2024, 03:31:54 PM »
04C Z10 Press in Snubber
05A X77 Press in Snubber
Both with 12 bolts
1969 Z/28 Legends Certified
1969 Z-10 Under Construction
Dave69x33
« Reply #24 on: January 04, 2024, 04:50:58 PM »
Thanks all for the responses.
I updated the list:
12B, model?, VN, push in, HOT302
01B, X11, NW, push in, Iowa Jon
02D, X77, NW, push in, from RikerZ28 (assumed X77)
04C, model?, plant? push in, from L78 steve
04C, Z11, VN, push in, from 169INDY
04C, Z10, plant?, Z10, push in, from Dusk Blue Z
06?, SS, VN, bolt in, from KevinW
05A, X33, NW, push in, Dave69x33
05A, X77, NW, push in, from Iowa Jon
05A, X77, NW, bolt in, from x77-69z28
05A, X77, plant?, push in, from Dusk Blue Z
05E, X77, NW, bolt in from copo
06A, X44, NW bolt in, from copo
08E, model? NW, bush in, from x66 714
09C, X77, NW, push in, from Badshifter
09D, model?, NW, push in, from R68 GTO
Questions:
HOT302, I assume your 12B car is a very early build '69?
bcmiller, Good point.  I assumed all '69 bodies would have the center and outer axle snubbers so I did not think to ask for the 10 vs 12 bolt input. Some folks responded with the type of Camaro they have so I updated the list with a few question for some folks.
Dusk Blue Z, can you update your input to let us know which plant?
KevinW, your Oct68 Norwood car, what model and was it a early build?
L78Steve, what model and plant was your 04C?
x66 714
« Reply #25 on: January 04, 2024, 06:15:38 PM »
01B VN SS/RS 350 push in type....Joe
BTW my is a X66 325hp 08E of 1969 for the record
RikerZ28
« Reply #26 on: January 04, 2024, 07:55:39 PM »
My 02D is 12 bolt and is an X33
1969 Z/28 02D X-33 / L72
Dusk Blue Z
« Reply #27 on: January 04, 2024, 10:33:28 PM »
Both are Norwood cars.
R68GTO
« Reply #28 on: January 04, 2024, 11:17:25 PM »
Mine is an X44 COPO BE rear.
Just a pure speculative theory on this topic.  We have the change document that notes the move to bolt in style.  For late build cars (past normal production end date of July time frame), they may have received old style or a mix due to limited availability of new style bolt in.  I wonder what the design is of the 1970 Camaro snubber.....same bolt in, different bolt in, or push in?
1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,500 original miles
KevinW
« Reply #29 on: January 05, 2024, 01:31:05 PM »
My Norwood car is 10B of 68, 327 10 bolt auto.  No threads are cut in bracket holes.
