Author Topic: PS pump  (Read 5871 times)
crobjones2
PS pump
« on: May 14, 2008, 05:15:56 AM »
Is there a # cast or stamped into the original pumps? If so where would it be?
I am trying to verify I have the original
Chris
69 SS 350
Re: PS pump
« Reply #1 on: May 14, 2008, 05:37:18 AM »
Yes.
It's cast on the back of the pump housing and is not visible without separating the reservoir from the pump housing.
Your welcome.     :)
crobjones2
Re: PS pump
« Reply #2 on: May 14, 2008, 05:51:25 AM »
How does the reservoir come off?
Chris
69 SS 350
Re: PS pump
« Reply #3 on: May 14, 2008, 06:02:38 AM »
Remove the pump outlet union (where the power steering pressure hose mounts) and the mounting studs from the back of the reservoir.  Pull the reservoir off the pump housing.
Your welcome.     :)
