Author Topic: Quadrajet Number  (Read 12709 times)
dsags
Quadrajet Number
« on: February 19, 2008, 11:32:52 PM »
I came across a Rochester Quadrajet with the number 29204  FF  1409. The number is NOT 7029204. Has anybody ever seen one like this ? Thanks.
tim69camaro
Re: Quadrajet Number
« Reply #1 on: February 20, 2008, 12:14:26 AM »
I have seen several this way. One just sold on ebay with an intake. Did you buy that one? Here is a link to the website that describes the 70 being dropped on some carbs.  http://camaros.org/carb.shtml
Tim Bailey
dsags
« Reply #2 on: February 20, 2008, 02:05:29 AM »
Thanks for the reply. I looked at that site and missed that reference the first time.  :(
Ejam
« Reply #3 on: February 26, 2008, 04:09:57 AM »
so some came with the 70 and some without?
dsags
« Reply #4 on: February 26, 2008, 02:35:11 PM »
In the detail for a 29200 carb for sale on eBay the seller said "all 1969s manufactured in this time period had the entire number on one line and to do this they eliminated the 70. Later on the date code was dropped below the oem number of the carburetor". His carb was dated 0149. Mine is 1409 or May 20th. It would seem that in this date range the 70 would be missing IF his statement is correct.
Ejam
« Reply #5 on: February 26, 2008, 08:12:14 PM »
« Last Edit: February 26, 2008, 08:17:34 PM by Ejam »
« Reply #6 on: February 26, 2008, 09:58:38 PM »
Read THIS gents. When I was writing the report, I emailed Jon Hardgrove about several things including this. He said there never seemed to be a rhyme or reason for the 5 digit stampings, but it appears mostly in 68 and 69 carburetors (although he's also seen it in later carbs).
Ejam
« Reply #7 on: February 27, 2008, 04:19:22 PM »
l like the application for 69 396 a/t being 7029200
dsags
« Reply #8 on: February 28, 2008, 02:36:45 AM »
Thanks for setting us straight Ed. Another myth bites the dust.
opelitis1
« Reply #9 on: February 28, 2008, 12:10:01 PM »
I have a couple of 29202 DH 0869 units, I will check the Julian date as I have them being the same (0869) for both.. How rare is that to have 2 of the same date???
Also have an '69 Olds 29251 RJ 1149 and a '72 Olds 2251 (only 4 digits) then RE 2651.
Hope I haven't sullied the Camaro parts with Olds parts numbers, but I kinda found it interesting that there was a 4 digit code i.e. 2251..
Some of the older carbs I have are seized: 7026202 - data disc unit   - one of the  two 29202 units   - and a 7029268 ('69 Poncho) is seized.  Not a real load of rust on these carbs, but, what is a safe way to "free 'em up" without killing the throttle plates and associated linkages???  T.
