Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
crager ss wheels help ????
« previous
next »
Print
Pages: [
1
Author
Topic: crager ss wheels help ???? (Read 6052 times)
john302
Member
on:
January 13, 2008, 02:48:56 PM »
Does anyone know if the new crager ss wheels that you can purchase today are the same as the ones in the 60/70s?If they are different what has changed on them? also what size would look/fit the best on a 68z/28. 15 inch by 6 or 7inch with the stock Goodyear Wide treads. Thanks John
Tweet
Logged
ss jim
Member
Re: crager ss wheels help ????
Reply #1 on:
January 13, 2008, 03:22:12 PM »
I think the spoke has changed somewhat. There was a discussion on another board about this not lond ago. I have not had a chance to compare side by side. Maybe someone who has actually seen them can chime in. Jim
Logged
z-villejw
Member
Reply #2 on:
January 13, 2008, 10:30:32 PM »
I have some on my 68. They are about year & half old. The new ones are all uni-lug and have alot better chrome on them ibn the lug area. If you have a factory disk brake car you will have to run a spacer in the front to keep the calipers from hitting the spokes. I have 15x6 on front & 15x7 on rear. They give it that Grumpy Jenkins Super Stock look!
Logged
J. Wiles Southeastern Ohio
1968 RS SS Coupe with 1967 427-435 Tri-power
Tripoli Turquoise with Black Vinyl Top
4 Speed with 3:31 12 bolt
john302
Member
Reply #3 on:
January 14, 2008, 02:38:30 AM »
what is the offset on yours? what thickness spacer? what size tires ? do they rub? thanks john
Logged
z-villejw
Member
Reply #4 on:
January 16, 2008, 12:14:09 PM »
They are what ever stock is. The spacer I used was made by Mr. Gasket, I think it is around 7/16. If you have front drums you won't need it. Front tires are 215-60-15 rears 255-60-15. No rubbing at all. Hope this helps John
Logged
Print
Pages: [
1
« previous
next »
General Discussion
