Author Topic: L30M20 Tire Pressure Sticker  (Read 6315 times)
rd67RSSS
  • Guest
« on: November 09, 2007, 01:02:19 PM »
Hi,
I have a car we bought for my wife last fall that I'm hoping to start restoring soon which is either a Norwood 06C 67 RS/SS Convertible or a possible  67 RS (L30M20, 327/275 HP) as the car was pretty cut up on the firewall for drag racing from 1971 to 1982 or so and although it has the 1" hole toward the center where the muncie speedo cable should be, the hole for console guages, and a 12-bolt I'm looking for more identification items.  The tire pressure sticker on the glove box is somewhat ledgible and has an "H" in the chevy emblem.  Since its an H I know this is what the SS350's recieved for a tire pressure sticker as the regular RS's and L30M20 would have a "G".
Could an L30M20 RS in 67 be ordered with the larger tires and have the "H" tire pressure sticker detail?
The 3rd owner back, who got the car back in 71 said it was all apart, but came with a 350 295 HP, center console with gauges, manual drum brakes, was irmine white, deluxe blue interior and with a blue top.  The gentlemen doesn't recall for sure if it was an RS or RS/SS as the emblems were gone and he doesn't recall if it had the bumblebee stip and painted it shortly therafter when he turned it into a IHRA Formula Stock car that set record back in the 70's.
Anyone have all the data on the tire pressure stickers and what the L30M20 vs. SS350's could have been ordered with?   Could a L30M20 (#27/275 HP) have had the H sticker or is the car a L48 SS350?
Thanks!
RonM
Re: L30M20 Tire Pressure Sticker
« Reply #1 on: November 09, 2007, 08:02:05 PM »
Go to the opening page of the CRG website and click on General Info. Number 17 should answer your question. My car (68 L30/M20) came with disc brakes and the disc brake rally wheels so the original owner probably ordered the optional tires as well, I don't know for sure. What I do know is the original sticker indicates a 78-series tire. Hope this helps, RonM.
rd67RSSS
« Reply #2 on: December 26, 2007, 06:20:35 PM »
Thanks for the reply Ron!   Its been quite some time and I'm surprized that I didn't hear more feedback on this....
I was hoping that someone on here can tell me what size tire was used on a 67 camaro with an "H" tire pressure sticker on the glove box?
Also, the car came with drum brakes, which width and "code" 14 inch rims would be used to mate with the "H" size tires?
Thanks so much.
Rick
« Reply #3 on: December 27, 2007, 04:50:50 AM »
You could get the wider 14x6 wheels on an L30/M20 as RPO P12 (code FC, off the top of my head) but if your car had a 350 in 1971 and has a Muncie speedo hole in the firewall, I think that tells you more than any tire sticker would.
-Jon
