Author Topic: Please help me verify my 1967 Z28 Camaro  (Read 18417 times)
Bob
« on: August 14, 2007, 09:48:10 PM »
 I am the owner of what I think to be a real 1967 Z28. The issue is
 that when I purchased the car 7 years ago, the trim tag was missing. I
 assumed is was originally an RS SS car, so a badged it accordingly. It
 does have the original bracket for the rear support arm to the diff,
 making it a 12 bolt car. It did originally have a 4 speed, still has the
 original disc brakes and manual steering. When I was doing an engine
 swap this summer, I found a hole that had been covered up on the top right
 of the firewall. It was a hole about 2" tall by 10" long. I am
 currently trying to track down the previous owner who used to race the car. It
 is still a very solid street car. It now has a 350 / 4 speed / 12 bolt rear and none of these were in the car when I purchased it. It is  a  Norwood car. I purchaed it in Illinois, it spent some time in Texas with the previous owner and I live in Colorado. Any ideas on tracking down some
 supporting documentation?? I have sent letters to the previous owner, no response. Vin number: 124377N251190
olympic69
Re: Please help me verify my 1967 Z28 Camaro
« Reply #1 on: August 20, 2007, 12:46:20 AM »
You might want to try contacting Camaro clubs in areas where the car was known to reside. There are several clubs around- maybe someone remembers the car. Just look at the story Jerry MacNeish relates on his web site Ref his latest aquisition!
Good luck. And, if the car was in the Dallas area, let me know- maybe I can help.
Rob
Olympic Gold X33
"Its all crazy..."
Jonesy
  • 1969 Camaro z28
« Reply #2 on: August 20, 2007, 03:20:41 AM »
Thats going to be a tough one to prove without the original tag, IMO. Any car can be cut for cowl plenum. Your car has some of the right stuff.
Original rear is gone? That may have helped knowing the ratio.
1969 Z28 Azure Turquoise
67L48
« Reply #3 on: August 20, 2007, 02:10:46 PM »
Bob,
Not sure what part of Colorado you live in, but there is a Camaro club based in the Denver area.  Between Jerry Mac and Larry Christiansen (sp?), you have two of the best Camaro resources in the world.  There is a car show in Arvada this weekend and the Colorado Camaro Club will be in attendance.  Not sure if Jerry or Larry will be there, but there should be some good people there to talk to, show pics to, etc.  Good luck.
67L48
1967 Camaro SS 350
PG, factory air, console, fold down rear seat, PS, PB, butternut yellow, #s matching, original manual/warranty/POP, <60K miles
Northeast Iowa
Jerry@CHP
« Reply #4 on: August 21, 2007, 12:09:16 AM »
Larry should be there, call him, 303-278-8536, he never misses a car show.
Jerry
Bob
« Reply #5 on: August 21, 2007, 01:21:26 PM »
Bob,
Thank you for the info.
Bob
Ron C.
« Reply #6 on: August 21, 2007, 04:47:22 PM »
does the car have a factory tach? if so where does the redline start?then look at the heater core cover,is it a small block heater core with the tubes on the right side of the cover or is it a big block core with the  outlets in the center of the cover?  ???
Bob
« Reply #7 on: August 21, 2007, 05:21:50 PM »
Thank you. It no longer has a factory tack. The heater core is for a small block. I have been able to verify that the vin number does fall within the production run of the Z28's built in Norwood.
Bob
Bob
« Reply #8 on: August 21, 2007, 05:23:12 PM »
Thank you very much!
Bob
« Reply #9 on: August 21, 2007, 09:27:35 PM »
How about the tire presure decal on the glovebox door? What's the tire size?
Bob
« Reply #10 on: August 22, 2007, 12:17:20 AM »
The glove box decal is there, but no tire size is mentioned, just pressure and number of vehicle in car, etc. I thought that they did not start the wheel size until 1968, but I could be wrong.
Bob
Bob
« Reply #11 on: August 22, 2007, 12:29:14 AM »
The part number on the decal is 3917572 and their is a "G" in the middle of the bowtie. Does this help?
Bob
Jerry@CHP
« Reply #12 on: August 22, 2007, 01:02:02 PM »
1967 Z28s did not receive a special tire sticker.  They used the "G" sticker.  Many of the early 1968 Z28s did not receive the correct E70x15" tire sticker either, my survivor has the standard "AG" sticker and have seen others with this too.
Jerry
Bob
« Reply #13 on: August 22, 2007, 01:07:51 PM »
Thank you very much Jerry. I appreciate your help!
Bob
« Reply #14 on: August 22, 2007, 11:43:45 PM »
Sorry I tried to mislead you. Stuff gets jumbled up in the grey matter sometimes. '67 doesn't have the size.
