Author Topic: 68 302 engine mounts  (Read 7404 times)
68Zproject
« on: July 03, 2007, 06:11:21 AM »
I read through the threads on this, but I wanted to try and clarify something about the replacement engine mounts.  I have the original frame stands verfied by the part #s still on them and I bought engine mounts from Rick's for the original frame stands.  The confusion lies in the discussions about the interlocking engine mounts not fitting the frame stands not made for the new interlocking engine mounts.  Was this meant for the 69 engine mounts not being used with 68 frame stands?  Or would all the new mounts that are now the interlocking design need to be used with 69 type frame stands?  In a previous post, someone said that the replacement engine mounts were all the interlocking kind now and I got confused with whether the 68 engine mount replacements were now the same as the 69 engine mounts or still different.  The engine mounts I purchased were for the original 1968 frame stands.  Thanks.
68Z28
68Zproject
Re: 68 302 engine mounts
« Reply #1 on: July 09, 2007, 04:57:36 AM »
No thoughts on this?  I read the thread about the engine mounts and the CRG article.  I'm still confused. ???
68Z28
KevinK
    • Hudson Valley Camaro
« Reply #2 on: July 09, 2007, 11:57:28 AM »
 ...not exactly sure myself what the specifics are with regard to fitment of original mounts vs. the repro mounts, ...However I found this information very useful ==>
http://www.pozziracing.com/camaro_engine.htm
sd1968z28
« Reply #3 on: July 09, 2007, 06:30:27 PM »
i bought new gm mounts they fit perfect, i also have the original worn factory ones if that is what is wanted?
68Zproject
« Reply #4 on: July 10, 2007, 05:33:12 AM »
Thanks for the link and info.  I think the repros will work.  For some reason I thought maybe all new mounts were for the 69 type stands.
68Z28
