Author Topic: 230 Heat riser flap removal  (Read 59 times)
mrile
« on: May 14, 2025, 01:09:02 AM »
Does anyone have any advice on how to remove the heat riser flap/valve (unsure the official term) in the exhaust manifold.  Mine is seized & I can't find anything on how to remove it.  I don't see any retaining rings or anything so i'm not sure what's holding it in or how to get it out (simply press it out?).  Any advice is appreciated.
GMAD_Van Nuys
Re: 230 Heat riser flap removal
« Reply #1 on: May 14, 2025, 02:01:10 AM »
GM has a spray that is used to lubricate the heat riser flap:
https://www.amazon.com/Genuine-GM-88862628-Penetrant-Inhibitor/dp/B00BK7MLKE?th=1
You could also try Kroil penetrating oil.  I don't believe you can remove the flap without cutting the shaft.
KevinW
« Reply #2 on: May 14, 2025, 12:20:53 PM »
A small cut-off wheel (dremel), can cut the metal flap and leave the shaft in place.  That is what I did.
