Author Topic: Cancel cam spring  (Read 17982 times)
x66 714
Cancel cam spring
« on: October 11, 2023, 02:43:02 AM »
68 w/o tilt, does it have a spring between the cancel cam & steering wheel hub? I've looked in the parts book & the assm manual. My research was inconclusive. Thank you, Joe
HOGDADDY
Re: Cancel cam spring
« Reply #1 on: October 11, 2023, 02:54:21 AM »
Here is a diagram.
169INDY
« Reply #2 on: October 11, 2023, 03:20:11 AM »
Yes.
Photo of mine Std Z28 floor shift NON tilt column
While the Diagram above clearly shows Piece number "one" the steering wheel retention nut, it lacks the info on the spring, and insulator, rotating contact, etc,etc.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
x66 714
« Reply #3 on: October 11, 2023, 03:41:38 AM »
Thank you for the picture. It's what I needed. The diagram I had but too generic......Joe
169INDY
« Reply #4 on: October 11, 2023, 04:51:34 AM »
Glad to Help Joe
v/r
68 Z28 M21 LOS
HOGDADDY
« Reply #5 on: October 11, 2023, 01:00:48 PM »
It's not real clear but it's there.
x66 714
« Reply #6 on: October 11, 2023, 01:38:02 PM »
Hogdaddy, I see now. It must've been serviced in a kit according to that grouping. Thank you, Joe
169INDY
« Reply #7 on: October 11, 2023, 05:12:09 PM »
Weird, ?? that Can not be it. Look to the Right, this spring we are discussing is NOT stacked  below (i.e. to the left) the Wave washer, Flast Washer and C clip.
The spring in questions Sits on top of the clip & washers.
Piece #7 is the Upper bearing assembly, ALL items shown in the parentheses are considered part of the bearing assembly fully assemble and NON separable.
Could this be a drawing error?
68 Z28 M21 LOS
x66 714
« Reply #8 on: October 11, 2023, 05:44:27 PM »
Anybody have a lenght of the spring? I found one that's 3/4 inch & I think that's too short....Thanks again, Joe
David K
  • Dr. Longblock
« Reply #9 on: October 11, 2023, 06:41:12 PM »
Is thatspring about 1/4" wide and has a few bends? About 3" long?
HOGDADDY
« Reply #10 on: October 11, 2023, 06:58:57 PM »
It is considered part of the bearing assembly.
x66 714
« Reply #11 on: October 11, 2023, 07:57:50 PM »
I think it should be 1.01" x .77ID according to something I found in some older parts book. Can anybody confirm that please? Thank you....Joe
169INDY
« Reply #12 on: October 12, 2023, 01:44:21 AM »
Spring Type: Compression
Spring End type design: Closed & Ground
Wire Diameter: 0.100"
Free Height: 1.100"
OD: 1.000"
Maybe McMaster-Carr    9657K324
In my mind the Steering Column Drawing has the "Spring" in the incorrect location.  As seen in FIGURE 24 & Based on the ID/OD of the spring it sits on top of the Wave washer/Thrust washer/Retaining Ring. & based on how I just took my Column apart & reassembled a few minutes ago.
Minor Point I suppose no real issue
68 Z28 M21 LOS
x66 714
« Reply #13 on: October 12, 2023, 03:18:05 AM »
Thank you Jim. I still have some more boxes to dig through.....Joe
