Author Topic: Left Hand Door Buzzer Switch for 1968 Camaro Standard Coupe  (Read 5848 times)
gwp4
« on: October 10, 2023, 01:59:58 AM »
Hi First Gen Camaro Experts -
Does anyone have the correct GM part number for a factory-installed silver zinc/cad left hand door buzzer switch that was on a 1968 Camaro standard base model coupe?  I'm looking to purchase an NOS switch to replace an aftermarket one on the car now.  Many thanks.  gwp4
68 Ragtop
Re: Left Hand Door Buzzer Switch for 1968 Camaro Standard Coupe
« Reply #1 on: October 10, 2023, 02:07:40 PM »
There is no actual door buzzer. The buzzing is accomplished by back feeding the horn relay. What you are looking for is a horn relay. Hope that helps you search.
David K
  • Dr. Longblock
« Reply #3 on: October 10, 2023, 07:42:21 PM »
Are you looking for the door switch? The courtesy lights will come on when the door is opened. The buzzer only sounds if the key is in the ignition switch.
169INDY
« Reply #4 on: October 10, 2023, 08:29:39 PM »
Here is my Factory Driver Door Jamb Switch; Two pin/prong
My car is apart, and the switch was successfully sent to a plater for Clear Zinc plating. The bayonet plunger was stuck but was able to force apart to allow spring action and proper operation. The Zinc tank plating is a cold process and was NOT harmful to the insulating plastic internals.
Others with Parts books might have PN or repair service item PN, since this was part of the Body Harness and installed by Fischer it is Not Shown  in the Factory AIM manual.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
169INDY
« Reply #5 on: October 10, 2023, 08:35:09 PM »
WHITE = Dome
BLACK = Ing Sw Key Alert (Horn Relay w/ Buzzer)
68 Z28 M21 LOS
David K
  • Dr. Longblock
« Reply #6 on: October 10, 2023, 11:36:47 PM »
That buzzing noise I refer to it as my "car alarm".
rare396bronze
« Reply #7 on: October 11, 2023, 10:01:41 PM »
original number was 391307 changed to 9662504 left side dome switch.
