Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
sender unit
« previous
next »
Print
Pages: [
1
Author
Topic: sender unit (Read 7964 times)
Egoreno1toy
Newbie
sender unit
on:
May 26, 2023, 03:43:35 AM »
ok, gauge is pegged at 3,I've checked harness to gauge when I ground harness,gauge goes pass empty.Now I have cleaned ground wire from sender under car and touched a known ground and I get no gauge movement. Does that mean sender is bad
Tweet
Logged
Hero Member
Re: sender unit
Reply #1 on:
May 26, 2023, 04:32:10 AM »
Yup.
a Open or infinite resistance in the circuit Pegs the Dash gage. (F)
a Short or direct ground (0 Ohms resistance) in the circuit Sets the Dash gage (E)
If I am understanding your troubleshooting steps, I think your Sender wiper/variable resistor is bad or the connection to the pin terminal has come unhooked.
Logged
Egoreno1toy
Newbie
Re: sender unit
Reply #2 on:
May 26, 2023, 11:30:18 AM »
Yes,gauge moves from past F to past empty during tan wire grounding test. after plugging back in tan,cleaning wire from tank strap and grounding I'm getting no movement off F. I'm guessing bad sender or connection of ground near sender
Logged
Print
Pages: [
1
« previous
next »
Maintenance
sender unit
