Author Topic: Correct Oil fitting L35  (Read 5467 times)
luv2sixty9
« on: November 14, 2022, 04:40:19 PM »
Wanting to ascertain, which is the correct original one if any for a 05E NOR68 Camaro SS 396/325hp with Oil Light / Idiot Warning Light.
I believe it's the top one but not absolutely sure.
Looking for concrete answers no guessing. Thanxs in advance
« Last Edit: November 14, 2022, 05:04:15 PM by luv2sixty9 »
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
Re: Correct Oil fitting L35
« Reply #1 on: November 14, 2022, 04:46:09 PM »
My LOS (12E) is equipped with the middle set up.
luv2sixty9
« Reply #2 on: November 14, 2022, 05:03:05 PM »
12E of 67, so early 68 LOS car? Mine is a NOR 05E of 68
1969 RS SS Pace Car
« Reply #3 on: November 15, 2022, 03:27:20 AM »
Correct Model Year 1968
68 TT
« Reply #4 on: March 08, 2023, 08:18:42 PM »
My 01C LOS 396 car has the upper one-piece 45-degree fitting.
It makes sense that they would use as few pieces as possible to eliminate parts, the labor to assemble them and possible oil leak locations.
big iron
« Reply #5 on: March 13, 2023, 05:28:05 PM »
Top picture is correct for 444052 elbow used on 67 68 69 2 bolt BB's. When the AIM RPO L35/U17 instructions where drawn they added the bushing 444026 / 444030 U17 which is not used on 2 bolt blocks but 444030 is used on 4 bolt blocks.
2 bolt BB blocks are drilled for 3/8" NPT and 444052 elbow screws directly into it with no adaptor ( bushing).
4 bolt BB blocks are drilled for 3/4" NPT and 444030 reducer bushing (3/4" to 1/2")  is needed but 444052 elbow is not used.
Bob
« Last Edit: March 13, 2023, 05:48:23 PM by big iron »
