Author Topic: Heater Core  (Read 4840 times)
LZDICK
Heater Core
« on: April 18, 2022, 04:34:32 PM »
New to this forum; looking forward to learning more about 1st Gen. Camaros.
I have a heater core question:  Which 1st Gen. Camaro takes a 2" (thick) heater core?  I recall '67-68 differed from '69; not sure which is which?  I believe the other was thicker; perhaps 2.5".  Reason:  I have a nice copper 2" heater core that I (hopefully) do not need.
Thanks CRG
rich69rs
  • LF7/M35/Z22/Z87
Re: Heater Core
« Reply #1 on: April 18, 2022, 08:39:36 PM »
Pictures of my original heater core from my 01C Norwood ‘69 RS.
Core is 2” thick,’.
Richard Thomas
1969 RS
Quickkiwi
  • Out Living The Life
Re: Heater Core
« Reply #2 on: April 24, 2022, 09:14:11 PM »
Just removed heater core from my 68.
I always believed 67-68 were 2.5" and the 69 was 2".
This surprised me being only 2", (# 68C) perhaps being a July 68 build it got a change that went into the 69 model.
Re: Heater Core
« Reply #3 on: April 26, 2022, 02:33:40 AM »
67 M
Re: Heater Core
« Reply #4 on: April 26, 2022, 02:34:28 AM »
68 E
Idk why the photos are upside down.  On my phone so I can’t fix until I’m on a pc.
Quickkiwi
Re: Heater Core
« Reply #5 on: April 26, 2022, 04:59:47 AM »
Found some good information, 2.5" was superseded in March 68 by the 2". Same case was used right through just different clips and pipe seal.
3015134 - Case - 1968-69 Camaro (except 396 engine) without AC
*use CI Part # 3013319 for 1968 Early Builds with 2-1/2" core
*use CI Part # 3011432 for 1968 Late Builds with 2" core (supersession #3016842)
*use CI Part # 3011432 for 1969 models
3015141 - Case - 1968-69 Camaro (with 396 engine) without AC
*use CI Part # 3011477 for 1968 models
*use CI Part # 3018864 for 1969 models
3015606 - Case - 1968 Camaro with AC
*use CI Part # 3009917 for 1968 models
3018763 - Case - 1969 Camaro with AC
*use CI Part # 3018489 for 1969 models
Re: Heater Core
« Reply #6 on: April 26, 2022, 12:25:51 PM »
Anyone have any clips for the 2.5" heater core?  I am in need of some or I will have to make my own.  Where did you come across the info? Thanks.
Quickkiwi
Re: Heater Core
« Reply #7 on: April 27, 2022, 01:11:28 AM »
I got the information from the following link on another forum. I cant find information on the clip for the 2.5". I could only find a 2.5" core here in NZ so I will use that to replace my 2". I will update how I get on with installing. I'm thinking I will have to make clips also.
Link
https://camaroforums.com/forum/67-69-general-43/heater-core-84014/page2/
Hope link is allowed, If not moderator please remove.
