Author Topic: NOS Coil Springs with Part Number without 2 Letter Code  (Read 6066 times)
jbtech
« on: November 28, 2021, 08:09:57 PM »
I purchased a few sets of NOS coil springs with tags but none have a 2 letter callout on the tag.
For example: The set I have here is part number 3955722
Are they correct for '69  "YP" or "YM" code or both?
Are springs with the same part number identical and the 2 letter code just to clarify application?
Thanks!
Jose
Jose
67 Camaro L78
124377N212598
Gars68Tux
Re: NOS Coil Springs with Part Number without 2 Letter Code
« Reply #1 on: November 29, 2021, 05:26:20 AM »
You can look it up in the AIM spring chart. Part numbers and codes are listed there.
Garth
68 RS L30 AA 749 Fred Gibb Chevrolet
« Reply #2 on: November 29, 2021, 08:35:35 AM »
Not what OP is asking. He is well aware of that chart he tells me
Gars68Tux
« Reply #3 on: November 29, 2021, 12:48:07 PM »
He's asking for the code for 3955722, right ? I don't have a 69 AIM, but the codes are listed in the 68 AIM, so I assume they were in the 69 AIM as well.  That part number isn't valid for 68.
Garth
« Reply #4 on: November 29, 2021, 01:52:32 PM »
In attempt to answer his questions:
1.  The two letter codes were for factory workers to quickly grab the correct spring for the car they were working on; not necessary for sales across the counter later.'
2.  If the Part Number is the same, then the springs SHOULD be the same as was used in production.
Jonesy
  • 1969 Camaro z28
« Reply #5 on: November 29, 2021, 03:07:01 PM »
I would think the best explanation is that these are over-the-counter replacement springs and they would not have the two letter code like the assembly line production springs did.
The 2 letter code helped aid the assembly line workers select the correct springs.
1969 Z28 Azure Turquoise
jbtech
« Reply #6 on: November 29, 2021, 04:23:20 PM »
Thank you all for your replies. I'm going to rephrase my question.
GM replacement coil springs are sold by part number and do not provide a 2 letter code on the tag like assembly line springs.
Does this mean that assembly line coil springs with identical part number but different 2 letter code are also identical?
For example is 3955722 YP an identical spring to 3955722 YM?
Jose
« Last Edit: November 29, 2021, 05:04:42 PM by jbtech »
Jose
67 Camaro L78
124377N212598
jdv69z
  • 69 RS Z/28 52E
« Reply #7 on: November 29, 2021, 04:45:53 PM »
Yes.
Jimmy V.
« Reply #8 on: November 29, 2021, 06:04:20 PM »
Spring chart reference with some explanation on part number usage.
A new System of determining the correct front and rear Springs has been used for 1969 Camaro
passenger cars. The assembly plants use a computer to determine the correct spring based on
the RPO equipment on the dealer order.
This requires a new method of determining service springs. The information required to determine
the correct spring or springs is shown on the subsequent pages.
http://www.camaros.org/images/pages/chassis/69_spring_chart.pdf
Gars68Tux
« Reply #9 on: November 30, 2021, 02:47:24 AM »
 Thanks Bryon. I count 5 different ID codes for 3955722...I had no idea! ???
Garth
jbtech
« Reply #10 on: November 30, 2021, 01:46:08 PM »
Thank you all for the answers!
Jose
67 Camaro L78
124377N212598
