Author Topic: 69 Temp Sending Unit  (Read 4947 times)
WaltZ
« on: July 26, 2021, 03:10:22 PM »
Which temp sending unit came with a DZ motor build date 1st week of January 69 with console guages.
threaded stud or slip on type. just curious, mine has the threaded.
Thanks in advance.
« Last Edit: July 26, 2021, 03:42:51 PM by WaltZ »
x66 714
Re: 69 Temp Sending Unit
« Reply #1 on: July 26, 2021, 05:10:30 PM »
My 69 396 car with gauges has threaded connection. I would think yours is the same. It's the gauge & the sender that have to match....Joe
WorkinProgress
« Reply #2 on: July 26, 2021, 06:59:26 PM »
Uses the threaded stud for console gauges.
                          - Warren
Edgemontvillage
« Reply #3 on: August 04, 2021, 03:56:00 AM »
This should help:http://www.camaros.org/forum/index.php?topic=19429.0
x66 714
WaltZ
« Reply #5 on: August 04, 2021, 04:21:45 PM »
could there be a chance that an early 69 DZ January with console guages have the 68 sending unit.
is it possible gm just used up the 68's before going to the screw stud connector.
thoughts on this,
thanks
Edgemontvillage
« Reply #6 on: August 10, 2021, 02:56:28 PM »
thoughts on this,
thanks
Its unlikely that GM would have had an inventory of the 1968 version sender on-hand 5+ months into the 1969 production cycle. That said, the 1968 production "shorty" spoiler was used well into February and possibly early March 1969. What makes continuation of the 68 gauge sender a bigger challenge is that it would also require a compatible engine harness which would further complicate production. Of the original January built cars I've seen that were factory optioned with gauges I've never seen a 68 sender that's also original to the car.
WaltZ
« Reply #7 on: August 11, 2021, 02:53:28 PM »
thanks, all info that I too came up with supports the threaded post only.
