Author Topic: '67-'69 Trunk Lid to Hinge Shims  (Read 9225 times)
JohnDS
« on: April 20, 2021, 02:04:27 PM »
Did the factory ever use shims between the Trunk Lid and Hinges on '67-69 Camaros?
Thanks!
Edgemontvillage
Re: '67-'69 Trunk Lid to Hinge Shims
« Reply #1 on: April 20, 2021, 04:58:43 PM »
Yes, they did, here is an example from an original 1969 L78 Norwood built Camaro SS. Shims were installed after paint and required the hinge bolts to be loosed so the bolt(s) will show tool marks.
JohnDS
« Reply #2 on: April 20, 2021, 07:07:47 PM »
Thanks for confirming this + sharing pix Lloyd.
John
« Reply #3 on: April 20, 2021, 07:16:54 PM »
 Interesting edge shape on the shim, Lloyd.
Any pictures of what the actual shim looks like?
Edgemontvillage
« Reply #4 on: April 20, 2021, 08:32:03 PM »
'fraid not Mike, I've only ever seen them installed.
x66 714
« Reply #5 on: April 20, 2021, 08:44:44 PM »
Here's another shimmed lid...Joe
Edgemontvillage
« Reply #6 on: April 20, 2021, 10:30:40 PM »
One more example:
« Reply #7 on: April 20, 2021, 11:08:31 PM »
WOW that is anew crazy Detail not often replicated!
Basics: Shim the Aft Bolt Lower the Front edge of the deck lid? (Pivot effect)
« Reply #8 on: April 21, 2021, 12:07:25 AM »
I'm curious why a shim wouldn't be painted. I would assume the deck lid would have been fitted and shimmed (if needed) before paint at Fisher.
Kelley W King
« Reply #9 on: April 21, 2021, 12:21:41 PM »
My 12A norwood 69 had shims which were lost after disassembly. We had to shim it when we put it back together after paint. Used regular body shims.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
JohnDS
« Reply #10 on: April 23, 2021, 09:35:29 PM »
Since Fisher Body installed & fit Decklid pre-paint, it's likely that those delivered with unpainted shims were flagged during Final Assembly as having fit issues where shims were added (quick fix).
« Reply #11 on: May 17, 2021, 06:44:58 PM »
Has anyone ever noted a 67 or 68 survivor with shims or of the few found were they all 69's? I've looked at a fair amount of survivors and never saw that but we learn all the time..... Thanks for sharing.....
« Reply #12 on: May 17, 2021, 07:39:47 PM »
I have never seen any 67s or 68s with shims.
« Reply #13 on: May 18, 2021, 08:44:21 PM »
Prior to painting the deck lid heights can be altered by using a block and pulling the deck lid down to alter the hinge orientation, after painting you would have to use shims to keep from cracking or marring the paint.
« Reply #14 on: May 18, 2021, 09:52:33 PM »
I have “tweaked” deck lids by hand using a 2x4 wrapped with carpet and duct tape before. :)
