Author Topic: 2 piece rotor. Original?  (Read 4783 times)
DarrenX33
« on: April 16, 2021, 01:44:44 AM »
https://photos.app.goo.gl/zJWq93gd7nDDjUvb9
Wondering if anyone has ever seen this red stripe before? I’m rebuilding my front suspension.
1969 Z28 Rallye Green X33/M22/4.10
1972 Corvette
Re: 2 piece rotor. Original?
« Reply #1 on: April 16, 2021, 12:35:49 PM »
Check out the '69 Camaro Assembly Manual, Section J52 page A1. The front hub, steering knuckle and other parts were received as an assembly in production.
Standard J52 cars received assemblies #3954867 & 3954868. "RPO Z28" received 3954869 & 3954870. In my experience, std. parts had green stripes, Z/28 had pink, like connecting rods. May indicate Z/28 components had additional processing, such as shot-peening or crack checking.
Just a theory. Never saw markings on rotors.
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: April 16, 2021, 03:05:48 PM »
Here's some pics of mine FYI.
Jimmy V.
jdv69z
  • 69 RS Z/28 52E
« Reply #3 on: April 16, 2021, 03:08:18 PM »
2 more.
Jimmy V.
Petes L48
« Reply #4 on: April 16, 2021, 05:51:48 PM »
This is how the green marking paint is normally found, at least in 67.  On the hub up near the dust cap
DarrenX33
« Reply #5 on: April 16, 2021, 06:08:10 PM »
Additional processing? Maybe that’s it. Only one of my rotors has the stripe. Other one does not. The one with the stripe is drilled out, balancing? Other rotor with no stripe is not drilled.
I can’t seem to post pics right. Hopefully the link worked.
1972 Corvette
