Author Topic: 69 Steering Column Upper Bearing NON-TILT  (Read 2978 times)
WaltZ
« on: February 27, 2021, 08:33:48 PM »
1969 Camaro NON-TILT upper bearing replacement in steering column.
I was hoping to replace it while I have it apart.
Any Suggestions on removal and replacement, other than live with the slight wobble..
Thanks in advance.
WorkinProgress
Re: 69 Steering Column Upper Bearing NON-TILT
« Reply #1 on: February 27, 2021, 09:40:20 PM »
Possibly the '69 Chevrolet Overhaul or Service Manual will tell you the procedure. Those manuals also list the specialty Kent Moore tools you may need.
                           - Warren
KevinW
« Reply #2 on: February 28, 2021, 01:24:10 PM »
Is there something wrong with it, that a good cleaning in place and re-lube won't fix?
