Author Topic: 302 vacume readings  (Read 7587 times)
WaltZ
302 vacume readings
« on: November 24, 2020, 05:46:10 PM »
what's a common idle vacume on a fresh stock dz 302
just curious what others may have
Thanks in advance
W
mls68z28
Re: 302 vacume readings
« Reply #1 on: November 25, 2020, 12:24:47 AM »
around 11
Mitch,1968 Z28 03C Norwood,03/18/68,Seneca Falls NY,Z/28 Emblems.Purchase 05/04/78
« Reply #2 on: November 27, 2020, 07:07:51 PM »
Around 11
x2
PHAT69AMX
« Reply #3 on: November 27, 2020, 07:23:23 PM »
Might anyone have tried changing to a B28 Vacuum Advance Canister and attaching it to manifold vacuum so it is deployed at idle, in an attempt to increase idle timing advance and an increase in idle vacuum levels?
The B28 starts advance at 4" vacuum and give full advance at only 8" vacuum and adds 16 degrees of advance.
Since it gives full advance at only 8  inches it is steady and does not hunt at idle on manifold vacuum above 8 inches.
And it is still possible to start the car when hot even though there is approx 22 degrees of advance at idle
since the vacuum advance is not deployed until after the engine starts.
« Reply #4 on: November 27, 2020, 08:47:26 PM »
As per the instructions of JOHNZ that is the exact can many of us use.
« Reply #5 on: November 27, 2020, 09:38:20 PM »
B28 = VC1810 ??
« Reply #6 on: November 28, 2020, 03:34:37 AM »
« Reply #7 on: November 28, 2020, 02:08:32 PM »
X2
T off the manifold, 36*@3k, 72/76 jets. Just over 1.5 turns out gets me 11" at idle.
I think it was listed for 69's, picked up a nice manifold T to hook up vacuum to the distributor and brake booster.
PHAT69AMX
« Reply #8 on: November 28, 2020, 09:36:19 PM »
janobyte - 36 deg total timing advance @ 3,000 engine rpms without any Vacuum Advance, correct ?
Then the B28 16 degrees of advance at 8 inches of Vacuum on manifold vacuum get's added to whatever it is at idle.
B28 Vacuum Advance Canisters can be hard to find.
Each Brand Name in their wisdom gave it a different part number which makes it difficult.
Manifold Vacuum can also be gotten to by using a Tee in the Choke Qualifier hose.
What might be the B28 equivalent Vacuum Canister for an HEI Distributor?
« Reply #9 on: November 28, 2020, 11:34:33 PM »
Sorry didn't specify, correct. Hook your vacuum gauge up to the manifold in it's place.
PHAT69AMX
« Reply #10 on: November 29, 2020, 03:53:34 AM »
the original factory 302 set up had a B9 vacuum Advance Canister
4 deg initial static at idle and 32 deg total mech all in by 4,400 engine rpms for 36 total dist # 1111480
Stock '69 Z28 302 Vacuum Advance is 'B1' on PORTED Vacuum, correct?
which has totally different specs than the 'B28' Can, no?  'B1' Can is:
16 deg = Full Vacuum Advance
 8" Vacuum = Starts Vac Advance
16" Vacuum = Full Vac Advance
Stingr69
« Reply #11 on: November 29, 2020, 03:00:23 PM »
The B28 hooked up to manifold vacuum is a modification that works well along with a more aggressive distributor advance curve.  Not trying to keep the factory smoggy original thing here.
PHAT69AMX
« Reply #12 on: November 29, 2020, 08:57:54 PM »
Stingr69 - ok, hear ya, yes, the change does make it idle better does it not?
Some folks like all stock, some folks will make slight mods for improvement.
A different Vacuum Advance Canister and re-curve are easily reversed back to stock.
Was a Mr Gasket Brass Travel Limiter Pin Bushing used and di it reduce Mechanical Advance from 32 to 28 ?
Were the lightest springs from the Mr Gasket Kit used ?  Might idle vacuum be more than 11 inches ?  Thanks
